Thermostatic shower valve - reversed hot/cold
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by msfitzjd, Mar 2, 2009.
  1. msfitzjd
    msfitzjd New Member
    Mar 2, 2009
    As part of shower remodel, new supply lines were run to change location of shower valve. We were not aware that hot and cold lines were reversed.
    Fusion Hardware brand thermostatic shower valve was installed and does not mix hot and cold water; it is either all hot or all cold. Fusion has sent replalcement cartridge and check stop valves but same problem. Our plumber says it should not matter that hot and cold lines were reversed.
    Would appreciate any input before going back to Fusion with same complaint. If we switch to a pressure balance valve will the reversed lines still be an issue? From this forum, I understand that type of valve can be rotated.
  2. jadnashua
    Some, not all, valves can work with the supplies reversed. If yours can't, the only fix is to redo the pipes so the supply lines go where they were designed.
  4. msfitzjd
    msfitzjd New Member
    Mar 2, 2009
    Thank you!
    As we suspected. Thanks for the response.
  5. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Some manufacturers make reverse cartridges. I'd check on that before I'd redo any piping.
  6. msfitzjd
    msfitzjd New Member
    Mar 2, 2009
    Calling them today. Just didn't want manufacturer to automatically blame faulty plumbing for the problem since our contractor felt that the reversed lines shouldn't have affected the mix.
  7. jadnashua
    Your contractor is clueless...the instructions on any I've looked at (admittedly not a lot) all are explicit about which side is hot and which is cold. IF they can be switched, it will also explicitly state what needs to be done to do that.
    My guess is he never looked at the instructions. This only works someo of the time, and even then, the manufacturer sometimes makes changes, negating anything learned from previous installs...ALWAYS read the instructions.
  8. hj
    valve
    The design of the valve and cartridge determine whether it can be reversed. When the temperature drops below the setting, it tries to increase the hot water flow, but if that is acutally the cold water side, all it does is make the water colder so it tries even harder to add hot water. Therefore, saying "it doesn't make any difference if they are reversed", means that the plumber is either not a plumber or he is a very poor one.
Similar Threads: Thermostatic shower
Plumbing Forum, Professional & DIY Advice Fantini shower thermostatic mixing valve with 3 vol controls no cold water Mar 29, 2016
Plumbing Forum, Professional & DIY Advice Thermostatic shower valve - water hammer Jun 14, 2015
Plumbing Forum, Professional & DIY Advice Need help finding thermostatic shower valve May 14, 2015
Plumbing Forum, Professional & DIY Advice Shower squeals then water flow stops - Moen 3301 Thermostatic Shower Valve Nov 10, 2014
Plumbing Forum, Professional & DIY Advice Help Mounting Hudson Reed Thermostatic Bar Shower Mixer Valve. Nov 2, 2014
