I will be removing the Filtrete 3M-50 WiFi thermostat from a house that is being sold and I need to install a replacement thermostat.
The current AC System is a 4 ton unit single stage straight cool with single stage heat strips. The existing thermostat is a Filtrete 3M-50 has an adjustable differential from 0.5-2.0 degrees. Single stage cool and single stage heat. It is a 5 wire system C-W-Y-R-G
The hard part is that I need one that has a 2 degree adjustable differential swing to keep compressor cycle time from being too short. i.e. set for cool at 74 deg it will cycle on at 76 deg and cycle off at 74 deg.
I like Honeywell but looking all their their digital thermostats are preset to 1 degree differential.
Any recommendations?
