thermostat on rheem needs daily resetting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Paulab, Jan 1, 2009.
  1. Paulab
    Paulab New Member
    Jan 1, 2009
    The reset button on my thermostat on my rheem hot water tank needs daily resetting.I guess I will replace the thermostat or is there usually some other reason for this problem.Thank you.
  2. BAPlumber
    BAPlumber Plumber
    Jul 18, 2007
    Journeyman Plumber, business owner
    Vashon, Washington
    replace both the upper and lower thermostats. that should solve the problem.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would trouble shoot the water heater to determine exactly what is wrong.
    It is possible for an element shorted to ground to heat constantly on 120 volts after thr t-stat shuts off.
  5. hj
    reset
    One or both of the elements is shorted out and causing temperature overrun. Do NOTHING until you know what needs fixing, or you will be replacing things that are not broken. In fact, a loose screw on the upper thermostat will cause the same problem.
Similar Threads: thermostat rheem
Plumbing Forum, Professional & DIY Advice Thermostatic Mix Valve at Kitchen Sink? Sep 28, 2015
Plumbing Forum, Professional & DIY Advice Bottom port on kohler thermostatic valve Sep 4, 2015
Plumbing Forum, Professional & DIY Advice Thermostatic shower valve - water hammer Jun 14, 2015
Plumbing Forum, Professional & DIY Advice Evaporative Cooler Thermostat Troubleshooting Jun 10, 2015
Plumbing Forum, Professional & DIY Advice Need help finding thermostatic shower valve May 14, 2015
