Thermostat for this heater?
Discussion in 'HVAC Heating & Cooling' started by snafflekid, Aug 13, 2007.
  1. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    I'm repairing the electrical wiring to a suspended ceiling gas heater (which has a flue). The original thermostat was removed when the drywall was ripped out and replaced and only the box remains. The dummies replaced it with a recepticle! This controlled a fan as well as the gas valve. My question is if I can use a line voltage thermostat designed for baseboard heaters to replace this missing thermostat? I know that they don't all work bang-bang but some supply a variable voltage to baseboards and I cannot find any line voltage thermostats (at least in big box stores) which specify their operation. I assume that if I can see a mechanical switch inside the thermostat it would be bang-bang. Any other obvious indicators I am missing? I'm in search of an answer, I'm stumped.
  2. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    Most likely the correct answer is NO, one cannot use a line voltage baseboard heater thermostat for this application. The resistance alone would kill the 24 VAC transformer that drives the thermostat circuit. Using 110 VAC on the thermostat circuit would fry the controls on the heater. In other words, don't do it.
    My experience in this area is limited so maybe somebody can tell you how to do this. On the other hand, I'll put $5 down that says it can't be done...
  4. hj
    t'stat
    If this is a line voltage system, which is often the case with those heaters, then a simple line voltage thermostat will operate it. If the baseboard t'stats are a simple spst switch, there is no problem but they could be dpst, in which case they would be overkill for your use. IF the wires to the old t'stat were large enough that the remodelers could use them for a receptacle, then they are not likely to be low voltage wires.
  5. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    I owe $5? Crap!
  6. snafflekid
    Apr 23, 2007
    Electrical Engineer
    Heh, pay up! I need a new thermostat. ;) The heater fan turned on when I plugged a lamp into the recepticle! That was a momentary head scratcher.
    It is definitely line voltage, I just would rather not go through a trial and error process of buying the right thermostat. I vaguely recall that the variable output thermostats have an integrated faceplate/heatsink. ???
  7. CHH
    CHH New Member
    May 25, 2007
    Denver, CO
    I'll fax the fiver right over.
Similar Threads: Thermostat heater
HVAC Heating & Cooling Aprilaire 700 humidifier with Nest thermostat Feb 9, 2017
HVAC Heating & Cooling Recommend A Thermostat? Feb 8, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling How to control the heat using the thermostat? Nov 20, 2016
HVAC Heating & Cooling Thermostat won't power on Oct 30, 2016
