Thermosiphon System Design
Discussion in 'Solar and Geothermal Water Heating Forum' started by Quantumstate, Jun 26, 2011.
  1. Quantumstate
    Quantumstate New Member
    Jun 26, 2011
    Seattle, Ecotopia
    Just bought an imported thermosiphon evac tube system which I'm going to install on my house. 40 gallon tank at the top, with 24 evac tubes coming down. I want to connect this to my 38 gallon hot water tank.
    The solar heater is a no-pressure system, so I'll need a heat exchanger, and have in mind the Brazed Plate type, but no idea how to size it.
    Water will need to be forced through both circuits, so I have in mind a Liang DC pump on a solar panel for low pressure. OTOH I'll probably need hot water at night, so maybe this isn't such a good idea.
    I guess the heat exchanger would need to be on the roof, as I doubt the Liang could force water up one story to the roof. I'd rather not send domestic water all the way up there though, if I can avoid it.
    On the high-pressure circuit I have in mind teeing off the cold of the domestic hot water heater to go to the heat exchanger, and from there teeing into the hot side of the hot water heater. So water would circulate through the heat exchanger and hot water heater. I guess the pumps would need to be controlled by a differential thermostat, so the solar supplement is only on when it's warmer. Suggestions on brand for a thermostat, particularly one that has a network interface and computer software? (hopefully open source)
    Does my design seem sound?
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    the easier route would be to buy the exchanger, tank, pumps and controls as a package. Try these guys www.caleffi.com
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The weight of the hot water coming back down will almost balance it out so there would not be any heavy lifting. See "Density of liquid water" table in this wiki.
    http://en.wikipedia.org/wiki/Properties_of_water
  5. Quantumstate
    Jun 26, 2011
    Seattle, Ecotopia
    So my overall plan looks solid?
    Any idea how to size a Brazed Plate heat exchanger?
    This collector seems very efficient. What if the water gets up to 200 degrees, will it damage the hot water heater? I notice the T&P is set for 180, and would probably blow. Anyone had a problem with this?
    Should I run the domestic water up to the roof, or the low-pressure solar water down to the house? IOW, where should the heat exchanger go?
  6. cssolar
    cssolar New Member
    Dec 20, 2010
    agost alicante SPAIN
    non pressure swh
    Hi I have a non pressure vac tube swh on my house, I use the hot water direct, I have an auto boost pump to give pressure when I open a tap.
    If you want mains pressure I recomend a pre heat type swh, the water in the tank and tubes is non pressure but there is a copper coil heat exchanger in the tank that gives indirect mains pressure.
    how do you controll filling of your non pressure tank, assistant tank, electonic controll or manual fill ?
    Tony cssolar
Similar Threads: Thermosiphon System
Solar and Geothermal Water Heating Forum diy thermosiphon design question Aug 1, 2011
Solar and Geothermal Water Heating Forum Most Efficient Open Loop Geo System Oct 3, 2016
Solar and Geothermal Water Heating Forum Evac tube solar water system not working Mar 25, 2016
Solar and Geothermal Water Heating Forum Solahart Passive System Anode Source Nov 22, 2015
Solar and Geothermal Water Heating Forum Open system idea - thoughts? Dec 23, 2013
