Thermal Expantion Tank vs Thermal Expansion Relief Valve?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Grayfeathers, May 6, 2009.
  1. Grayfeathers
    Grayfeathers New Member
    Jul 11, 2008
    Maintanence
    Pleasant Grove, Alabama
    The Water Works dept. has decided to redo our water mains and install new water meters with a duel-check backflow preventer. The Water Works dept. has requested that the private owner install, or should I say have a professional install a Thermal Expansion relief device. They have suggested either a TE Relief Ball Cock, a TE Tank or a TE Relief Valve. I need some opinions as to what is best to have installed. I'm not planning on being in my house much longer (trying to sell) but I want to make sure that what is installed is up to code and will do the job.
    Thanks so much in advance.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I would opt for the expansion tank myself.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I'm not a pro so there are things I am not aware of. That said, the topic of thermal expansion comes up frequently on this forum. The only way I am familiar with is the thermal expansion tank as pictured in the previous post. These are used when the home has a closed system. A closed system is created when either a pressure regulator valve is installed or a meter with a check valve such as you describe. What happens is as we all know when water heats, it expands. If the system is open, the expansion is absorbed by the city water main. However, when the system is closed, there is no place for the expansion to go, so it will trip the T/P valve on the water heater. The thermal expansion tank is installed in the cold water intake between the PRV or check valve and the water heater. It is air charged to equal the house water pressure and will absorb this expansion. It is really a small volume of water that has to be absorbed, but with the tank, pressure in the water heater will rise rapidly and will exceed the 150 psi that the T/P is designed for. Installation is quite simple, it requires a tee in the cold water line to which the screw adapter is soldered. The tank screws on to the adapter. The tank does have to be very well supported. Tanks cost around $50 and come in at least 2 sizes to best fit the home. You will have to do this if the meter change is made while you are in the home, the T/P will immediately trip once the system is closed and the heater turns on.
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Yes the expansion tank is the way to go .
  7. Cass
    Cass Plumber
    Nov 12, 2005
    A tank is the way to go...
  8. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Just to add to your post. Expansion tanks can also help when you have a check valve/backflow preventer and there is fluctuation in pressure on the city side. Your system can experience higher pressure that cannot be relieved back into the city main.
  9. hj
    Te
    A thermal expansion ballcock is the least expensive solution. It will work until someone replaces the ballcock with a standard one.
  10. Grayfeathers
    Jul 11, 2008
    Maintanence
    Thanks for all the respnses
    I'll look into getting a Thermal Expansion Tank. Sounds like it's the way to go. I'll probably do it right and get a professional in here and do the job.
    Thanks again for all your help guys.
Similar Threads: Thermal Expantion
Plumbing Forum, Professional & DIY Advice Thermal expansion tank Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Thermal Expansion Valve -- in Toilet! Jul 9, 2015
Plumbing Forum, Professional & DIY Advice Thermal Expansion Feb 7, 2014
Plumbing Forum, Professional & DIY Advice Dripping thermal expansion relief value Oct 22, 2013
Plumbing Forum, Professional & DIY Advice thoughts on thermal expansion tanks Mar 20, 2013
