thermal expansion
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ally68, Jan 31, 2005.
  1. ally68
    ally68 New Member
    Jan 31, 2005
    Missouri
    I have some thermal expansion my pressure sits under 50 psi and never gets over 80 psi when heater is on and back down to 55 or 60 when it shuts off. One time I ran all the hot water out and let it heat up with out using the water and it only got to about 85 psi for about 5 minutes before it started back dwon to 60 psi should I worry?
    I really dont want to install anything.
    Thanks
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    You should be fine, if you have a constant pressure above 80 then a pressure reducer valve would be needed.
Similar Threads: thermal expansion
Plumbing Forum, Professional & DIY Advice Thermal expansion tank Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Thermal Expansion Valve -- in Toilet! Jul 9, 2015
Plumbing Forum, Professional & DIY Advice Thermal Expansion Feb 7, 2014
Plumbing Forum, Professional & DIY Advice Dripping thermal expansion relief value Oct 22, 2013
Plumbing Forum, Professional & DIY Advice thoughts on thermal expansion tanks Mar 20, 2013
