There is space between tub spout and fiberglass
Discussion in 'Shower & Bathtub Forum & Blog' started by marythefamilymanager, Feb 8, 2006.
  1. marythefamilymanager
    marythefamilymanager New Member
    Feb 8, 2006
    My upstairs bathtub/shower is fiberglass. This is the kids bathroom; they must have hit or grabbed the tub spout and shifted it a bit. I recently noticed that there is now a space where the spout comes out of the fiberglass; in other words, the tub spout no longer sits flush against the back fiberglass wall. In fact, there is probably about 3/8" open space at the underside of the spout and a more narrow space on top.
    Since this is an upstairs bathroom, I am concerned that water may splash back behind the tub and ruin the ceiling below.
    Right now, I am trying to keep the crack filled with plumbers putty.
    Is the plumber's putty a reasonable solution? Or does this sound like I need a plumber? Maybe a new tub spout?
    Our fixtures are Delta brand; I can't find a screw or anyway to tighten the spout.
    Thanks in advance for your help!
  2. jadnashua
    Usually, those that are slip-on have a set screw; those that don't are screwed onto a threaded fitting. If you unthreaded one that far, it would leak around the fitting. It sounds like the pipe may not have been screwed or anchored well in the wall and somebody pulled on it, bending the pipe.
Similar Threads: space between
Shower & Bathtub Forum & Blog Wood Sleepers over Torch-Down Primary Roofing Waterproofing: Exterior Deck over Living Space Oct 15, 2014
Shower & Bathtub Forum & Blog deck over space Aug 27, 2014
Shower & Bathtub Forum & Blog replacing tub/shower-need a tub that will fit in a limited space 60"x 30". Apr 6, 2013
Shower & Bathtub Forum & Blog Convert shower to bath - tricky space May 9, 2011
Shower & Bathtub Forum & Blog Safer: Electric Space Heater Or Bathroom Heater/Exhaust Vent Feb 15, 2011
