The real recieved from Happy Customer
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by speedbump, Mar 12, 2007.
  1. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I recieved this e-mail today from an internet customer.
  2. Rancher
    Rancher Guest
    That's awsome, Rube would be proud.
    But I'm confused... doing dishes? Isn't that's what dishwashers are for?
    Rancher
  4. speedbump
    Jul 15, 2005
    Riverview, Fl.
    Your just jealous Rancher, because your plumbing doesn't look like that.
    bob...
  5. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    The system does look nice.
    It would be interesting to see the how the flow/head characteristic and power consumption of a 1.5 HP jet pump with a "tricked" injector and CSV compare with a pump of the more usual size for household use.
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I'll leave that up to you Bob, your far better at that sort of thing than I am. I just know it works good and gives the desired effect at the faucets. When working with a jet instead of a submersible, you have to be creative.
    bob...
  7. Rancher
    Rancher Guest
    As I told speedbump on his site, of course it works better now that he's put in a CSV... of course he also went from a normal non-tricked 1/2 HP jet to this monster.
    Rancher
  8. Bob NH
    Oct 20, 2005
    New Hampshire
    I thought since you apparently sold the pump and maybe other parts of the system, you might be able to furnish the characteristics. If one knew the pump characteristics, pressure switch settings, and the size of the tank, it would be possible to compare it with a more standard system. Without those characteristics, there is no way to do a comparison.
    As you are aware, jet pumps don't drop off in kW as much as submersibles when they are throttled, becuase much of the flow is through the jet even when there is little discharge.
  9. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I can post a chart of the pumps abilities at differing pressures and lifts, but all I know about the tank is what you see in the picture. It looks very much like a Flotec somewhere in the neighborhood of 40 to 60 gallon equivalent. He is pulling out of an aerator so there is no lift. The switch is set at around 50/70. Here is the test we did on the pump with a CSV1Z and a 42 gallon bladder tank with a 5.9 gallon drawdown. The amps dropped by a third on this pump.
Similar Threads: real recieved
Pumps and Tanks Well Forum & Blog. Water is life. Replaced check valve, now no real flow. Aug 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Real world vs rule of thumb - How do you figure GPM & what happens if pump cannot meet demand? Oct 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Well pipe reality check Jul 30, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Do I have really have a well water line leak? Need second opinion. Jun 19, 2014
Pumps and Tanks Well Forum & Blog. Water is life. How do I test those water level indicator wires -- we have REALLY hard water and.... Dec 4, 2013
