the distance between drain trap and vent fitting
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 30all, Feb 23, 2006.
  1. 30all
    30all New Member
    May 24, 2005
    I need to move kitchen drain to left along with window. Search for the codes about boring 2x4 stub in exterior wall, it seems doable. but I don't know if I need to move vent along with drain. Since I only need to move 1 or 2 feet from current spot, I may be able to get away from moving vent?
    I don't want to bore 2 holes in 2x4 for both drain and vent. if I have to move vent, then I will route the drain pipe from basement and come out from floor into sink base cabinet.
    Check 2 plumbing books, they says 2 different numbers. :confused:
  2. Terry
    Aug 17, 2004
    For most kitchens, the trap arm is 1.5"
    the vent can be within 42" in the UPC code.
  4. 30all
    30all New Member
    May 24, 2005
    Terry, thank you
    The 1.5" you are refering to is the size of drain and trap, not length, right?
    the 42" distance is from p-trap to the vent T fitting?
Similar Threads: distance between
Plumbing Forum, Professional & DIY Advice Any Max and Min distance requirement between branches? Aug 29, 2014
Plumbing Forum, Professional & DIY Advice Distance between plumbing vent and bathroom van exhaust Oct 22, 2013
Plumbing Forum, Professional & DIY Advice Minumum distance between pex fittings? May 30, 2011
Plumbing Forum, Professional & DIY Advice Distance between Sump Pit and Ejector Pit Aug 13, 2007
Plumbing Forum, Professional & DIY Advice Sidewall vent - distance from window/door Thursday at 3:57 AM
