The cost of efficiency
Discussion in 'HVAC Heating & Cooling' started by bmccabe, Jun 30, 2008.
  1. bmccabe
    bmccabe New Member
    Jul 5, 2007
    Owner, Ferret Properties
    NJ
    Some context...I buy and renovate houses in the urban northeast. While their condition at purchase ranges from okay to not so hot, they are usually structurally sound. That said, they almost never have adequate insulation...if they have any at all...and building envelops offer little in the way of a thermal barrier. Of considerable importance is the fact that apartments in these houses often rent to Section 8 tenants.
    As a landlord I can opt to pay utilities or have the tenant pay, the difference being the amount of rent money I receive from the local housing authority (more if I pay). In either case, the amount of money earmarked for utilities is not sufficient to cover today's wildly inflated gas and electric costs. Now, to the heart of the matter.
    I am in the midst of rehabbing a three family house in Newark, NJ. It needs a completely new heating system...actually three systems...and I have opted to go with direct vent, gas-fired boilers feeding hot water baseboard registers, one boiler for each floor. Hot water will be provided by three, 199k btu, tankless water heaters. My goal is to make this house as green and as energy efficient as possible, while being mindful of a tight budget, in order to reduce utility costs. The reason is that even though the rent might be paid by the housing authority, astronomical heating bills will make the house unaffordable for the tenant or a losing proposition for me, depending upon who is paying the utility costs. So, here is what I am wrestling with: given the fact that it is economically unfeasible to seal and insulate the entire building envelope is there a benefit to paying the premium for high efficiency boilers (90% or greater) or would I be better off with lower efficiency (low 80s) while investing the price difference in more insulation (but still not the whole building)?
    In advance, thank you for any guidance you can provide. The efficiency of heating systems in affordable housing is an issue that will take on increasingly more importance as time goes on.
    Brian McCabe
  2. cattledog
    cattledog New Member
    Jan 29, 2006
    Portland, Oregon
    Brian--
    "The efficiency of heating systems in affordable housing is an issue that will take on increasingly more importance as time goes on."
    You are to be commended for trying to make this work out. The potential cost savings of energy efficiency are significant for Section 8 tenants.
    If you are going to use hot water base board heating, you should consider a 50/60 gallon indirect hot water heater coupled to the boiler. You then have the advantage of a high efficiency boiler providing the dhw instead of the tankless which have lower AFUE. My calculations indicate that the standby losses maybe less important than the efficency difference between the appliances. The tankless are best for "endless" hot water, but I'm not convinced of the actual energy savings.
    Your choice between insulation and boiler efficiency should be a straight forward analysis once you have the heat loss study for the building. One additional thing to consider is adding enough radiation so that you can heat the building with lower water temperatures. At lower water temperatures you can consider modulating and condensing gas boilers. Adding "outdoor reset" will adjust circulating water temperature down when its not too cold outside, and will provide additional efficiency and savings in the shoulder seasons.
    I don't know if you have a three story building, but it you do there will be significant heat loss differences for different floors. You may be able to leverage off that fact to make the building as a system work in your favor if you supply the heat.
  4. cattledog
    Jan 29, 2006
    Portland, Oregon
  5. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    Heat loss in larger buildings is dominated by air leaks.
    Personally I would suggest spending the money fixing air leaks and insulation.
    The furnace or boiler can the be changed out latter to a much more efficient system like a ground source heat pump.
    I see oil and gas staying high, while electric leveling off in terms of price.
    Edit: It's also good to think in terms of "Cap in heat" and "tub the cold" in that you get a bigger return when you seal leaks at the top floor and the basement.
    You might also have to plan for some sort of fresh air.
  6. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    That depends entirely on how the electricity is generated. If it is from oil or gas the price will have to mirror the cost of the fuel. Coal will follow general inflation for the most part and hydro will have the least increases due mostly to general inflation. Nuclear is anybody's guess.
  7. tomokariver
    tomokariver New Member
    Jul 21, 2008
    Energy Efficiency
    If you want to incerease efifciency with little cost then keep the condensor clean and free of corrosion. This may be a Catch 22 since common cleaners are not good for the environment. Go to www.adsil.com and then to the HVAC section. You can get corrosion protection without loosing heat transfer and you also can get a very hydrophobic surface that keeps clean without using harmful cleaners.
Similar Threads: cost efficiency
HVAC Heating & Cooling New "high efficiency" system operating costs are HIGHER -- help! Dec 12, 2011
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling Package heat pump vs gas pack -costs vs each other to buy Nov 2, 2014
HVAC Heating & Cooling Cost to duct small house for HVAC ?? Nov 7, 2010
HVAC Heating & Cooling Cost to extend gas line in garage? Oct 5, 2010
