Testing Drain Lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GeronimoDF, Oct 5, 2009.
  1. GeronimoDF
    GeronimoDF New Member
    Oct 5, 2009
    Long Island, NY
    Does anyone know a good link that talks about testing drain lines? I searched and searched.....I just replaced all the cast iron with 4inch PVC, and I want to test all the connections. Any hints? I read use a 10ft column of water which creates ~ 10psi. In order to fill it up, I would need to fill up 16 feet up. Is that the best way?
    Thanks,
    Dan
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    That would be OK. In some towns we had to flood the system through the roof.
    That put a 30' head on the pipe.
    John
  4. Inspektor Ludwig
    Inspektor Ludwig Journeyman/Inspector
    May 11, 2006
    In the good ol' UPC
    I think it depends on what code you use in NY. I would fill the all of the waste piping with water until it came out of the vents on the roof. The 10ft head of water results in around 5 lbs of pressure. The idea is to have at least a 10ft head of water over the HIGHEST joint in the system which would mean your last vent joint. Sometimes that's not possible so just filling the system with water through the roof should be adequate.
  5. dcelite
    dcelite Plumber
    Oct 5, 2009
    Los Gatos, CA
    You can fill the system with air if it makes any easier or less mess. Just cap off all the outlets and adapt to a pressure guage on one outlet (just like a gas test).
Similar Threads: Testing Drain
Plumbing Forum, Professional & DIY Advice Testing Drain Waste Vent Oct 21, 2010
Plumbing Forum, Professional & DIY Advice Testing this new Drain Nov 22, 2009
Plumbing Forum, Professional & DIY Advice Testing PVC drain lines Dec 28, 2006
Plumbing Forum, Professional & DIY Advice Testing plumbing with air, flux in pipes... Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
