Testing a new faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by penobscotman, Aug 8, 2014.
  1. penobscotman
    penobscotman Member
    Mar 18, 2013
    Buffalo NY
    I'm installing a shower (fibreglas enclosure) and I'm about to start on the rough plumbing. Copper, sweated fittings. Is there any way to test the plumbing for leaks before I install shower walls and the shower cartridge, etc.?
  2. hj
    Install the cartridge and turn on the water.
  4. penobscotman
    penobscotman Member
    Mar 18, 2013
    Buffalo NY
    I guess my question was almost too dumb to be answered, but thanks! Won't the water spray out? I guess I will find out!
  5. Terry
    Aug 17, 2004
    When testing a shower valve, you will want a test nipple with cap.
    When installing the trim, you remove that and install the shower arm.
  6. fullysprinklered
    fullysprinklered Well-Known Member
    Jun 15, 2014
    self-employed plumber-electrician doing residentia
    Georgia
    They're out there.
  7. hj
    If it "sprays out" then you have a leak, and you would have it no matter how you tested the faucet.
  8. penobscotman
    penobscotman Member
    Mar 18, 2013
    Buffalo NY
    I did everything everyone said -- no leaks. Thanks.
Similar Threads: Testing faucet
Plumbing Forum, Professional & DIY Advice Testing plumbing with air, flux in pipes... Dec 27, 2016
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Testing a copper line Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
