tester prongs not long enough?
Discussion in 'Electrical Forum discussion & Blog' started by goat1of2, Sep 9, 2008.
  1. goat1of2
    goat1of2 New Member
    Jan 30, 2007
    I'm trying to test a dryer outlet and neither my multimeter nor my el-cheapo receptacle tester has prongs seemingly long enough to make contact deep inside the outlet where the juice is.
    Am I just using them wrong or do I need to purchase Yet Another Tester?
    I toyed with the idea of extending the prongs by taping some copper wire on, but the thought of dying stopped me :rolleyes:
  2. jadnashua
    Turn the CB off, stick a piece of wire in there - attach it to the probe, turn the CB back on - read the meter, turn the CB off...repeat as required.
    Or, depending on the plug on the dryer, sometimes it will make a connection when not all the way inserted, you can stick the prong into that gap, using the dryer plug as your extender.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Trun off breaker and remove cover. Now everything is exposed for testing
    Edited to add;
    Of course if you had this knowledge you would know what you were doing in the first place
    Without this knowledge it is best you call someone who does
  5. hj
    outlet
    If you already have the dryer, insert the plug most of the way and then touch the visible portion.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    That is not a good idea...you are making an assumption that the breaker worked...which it will 99.999% of the time but that .001% could possibly kill someone under the right circumstances.
  7. hj
    testing
    You are also assuming the circuit breaker is labeled correctly and that you are turning the correct one on and off. Since many circuit breaker legends are an exercise in creative writing 101 and may not be correct do not assume anything, but check first. But I guess your problem is that you cannot check first, unless you buy a better tester.
  8. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Hire a professional electrician.
    Electrical work is not a hobby and can kill you.
Similar Threads: tester prongs
Electrical Forum discussion & Blog Outlet tester mystery Oct 20, 2016
Electrical Forum discussion & Blog electrical testers Apr 26, 2011
Electrical Forum discussion & Blog Need some recomendations on Electrical Testers Nov 7, 2010
Electrical Forum discussion & Blog Outlet Tester has all 3 lights on Jan 4, 2008
