JoshRountree
Hi, we've had record lows here and I thought my pipes froze at the well head, but now I'm leaning towards the pump is burned out. I've had heat tape and used my heat gun for 2 days.
Can you test a 2 wire pump? I disconnected the pump wires at the well head and tested for continuity between the 2 wires (not the ground), and got continuity. Seems like that is supposed to show a resistance since it's connected to the windings. If I show continuity between the 2 wires can I assume the pump is bad?
