Terrazzo Shower Base Installation
Discussion in 'Shower & Bathtub Forum & Blog' started by Marrkk, Mar 14, 2005.
  1. Marrkk
    Marrkk New Member
    Mar 14, 2005
    I'm planning to install a 42" x 36" terrazzo shower base (receptor). The manufacturer calls for it to be installed over a grout or plaster base, insuring even weight distribution to prevent cracking (other manufacturers list sand as an acceptable base). The sucker weighs 365 lbs! Any suggestions on positioning it above the floor and holding it up to prepare the grout, and then lowering it in a level manner to prevent the grout from being squeezed out unevenly? Any tools? I can set it on blocks at the corners, but would still have to remove the blocks and lower it w/out getting hands caught under it. Anyone out there set one of these?
  2. hj
    IN the past I have set a lot of them, although they are not as popular now because of the plastic ones. But I have never set them on anything other than the actual floor, and have never seen one crack. But if you want to use something just apply it to the floor and set the base down. The only place that might not get an even distribution would be the point you use as a "hinge" to lower it.
  4. Terry
    Aug 17, 2004
    You've got to be the strongest plumber I know.
    I installed one years ago that was a 48x34.
    It took four plumbers to carry it up the stairs.
    I can bring in a cast iron tub with two pretty easily, I don't know why the Terrazo pan was so hard.
    We replaced it two months later, the crack from the center drain just kept getting bigger.
  5. Marrkk
    Marrkk New Member
    Mar 14, 2005
    Cracking Terazzo Pan
    Terry -the terazzo pan that cracked - did you set it in mortar or sand? I've talked both to my supplier's rep (Florestone) and another Terazzo supplier (Acorn) and the both want a base material. I suggested to Florestone that I simply replace the subfloor with a piece of 1 1/8 Plywood that I very precisely support and make certain is dead level and flat. He said it's not just the floor, but that the bottom of the receptor itself is not flat, so the mortar/plaster fills any high/low spot in the undersurface of the receptor as well as the floor.
Similar Threads: Terrazzo Shower
Shower & Bathtub Forum & Blog Handling A Heavy Terrazzo Shower Pan Feb 2, 2010
Shower & Bathtub Forum & Blog Leaking terrazzo shower base drain seal Sep 4, 2008
Shower & Bathtub Forum & Blog Leaks with Terrazzo Shower Base - Long Post Jul 4, 2006
Shower & Bathtub Forum & Blog Which Terrazzo Shower Base to buy? Apr 24, 2006
Shower & Bathtub Forum & Blog Terrazzo leaking Jun 14, 2006
