temporary power pole
Discussion in 'Electrical Forum discussion & Blog' started by toolguy504, Jan 19, 2008.
  1. toolguy504
    toolguy504 DIY Junior Member
    Dec 21, 2007
    Chalmette, Louisiana
    I am putting up a temporary power pole and I would like to know if the conduit going from the meter pan up to the weather head has to be rigid metal conduit or can it be rigid EMT conduit or Schedule 40 conduit. Also does it mater if the weather head is metal or Schedule 40. Thank you.
    Earl
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    I would check with your local Power company, they may and usually have their own request along with following the NEC and any state amendments....
  4. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    Not sure if your utility has any special requirements, but in our area temporary services use SEC* cable and plastic weather heads. IT IS ONLY TEMPORARY as the saying goes.......................
    *service Entrance Cable.
  5. brownizs
    brownizs In the Trades
    Feb 9, 2006
    Springfield, IL
    All that I have seen, are wired as if it was on the house (Weatherhead, Meterhead, Main Breaker Outdoor panel, and either 3-conductor #1 or #2, or Conduit depending on the regulations in the area.
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    If I was doing the job I would just use SEU, but it really depends on where you live and what is acceptable...
Similar Threads: temporary power
Electrical Forum discussion & Blog Temporary power panel Aug 5, 2015
Electrical Forum discussion & Blog Power feed problems Monday at 10:55 PM
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
Electrical Forum discussion & Blog GFCI tripping with no load when connected to power Oct 7, 2016
