The handle on the plastic ball valve that is the cold water shut off for the bathtub sheared off somehow. It is leaking through the o ring that is now exposed. I discovered this when the kitchen ceiling underneath the hall bath showed signs of a leak. The leak was from the valve. The handle appeared to be just sitting there and when I touched it, just came apart/fell off.
Any temporary solutions so I don't have get up every five hours to empty the cup that is catching the drip? It is a small space so size of container is limited.
How concerned do I have to be that this will turn into a giant flood/catastrophic failure of the o ring? I am afraid to leave the house.
Any ideas what brand or type of ball valve to use so this does not happen again? It is only about 2 1/2 years old. I had to have all copper pipe removed and entire house repiped with cpvc due to repeated pin hole leaks.
I am concerned because I now don't trust the rest of the plumbing or ball valves.
And I am tired of repairing that kitchen ceiling.
I called the plumber and hope to hear from him bright and early Monday morning.
Thanks for any suggestions!
