Mike from Brier
We have a wet utility room due to a high water table, and old house with no footing drains, and a cement block foundation on slab. Our drainage and structural services contractor has installed a sump pump in a below grade tank in the corner of the wet area inside the house that is fed by perf pipe in a trench that extends four feet along each wall away from the tank. However, he needs to extend the trench on one wall about five more feet in order to eliminate the last remaining wet area, and that requires temporarily moving our water heater about three feet so it's out of the way during this procedure.
My question: is it okay to move the WH without first emptying it? I'd prefer to just disconnect it and slide it a couple feet away from the wall, but not if there is a significant potential for damaging the WH in the process.
