Tempering domestic water from wood heated tank
Discussion in 'Solar and Geothermal Water Heating Forum' started by Commonground, Oct 30, 2011.
  1. Commonground
    Commonground New Member
    Feb 1, 2011
    I hope this is the right forum for my question:
    I heat my water with a wood stove just installed this year. The stove is located on the first floor, the 180 l tank just above it on the second floor. The water gets too hot for safe use at the taps. The winter has not started yet and I already have had 75C at the taps.
    I would like to know my options to avoid being scalded: tempering valve, mixing valve, temperature limiting valve at the point of use, one lever faucet, etc.
    I have 3 taps: a one lever faucet each at the kitchen sink and at the tub and a 2 handle faucet at the bathroom basin.
    The latter is where the problem is more acute as it is very difficult to adjust, especially because of the long run of pipe between the tank and the tap.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    They make mixing/tempering valves both for POU and at the tank. Why not also sink some of the surplus heat to heat part of the home? You could put in radiant floor heat or a radiator.
Similar Threads: Tempering domestic
Solar and Geothermal Water Heating Forum Tempering valve operation May 10, 2008
