Temperature Pressure Relief Valve (TPR) re-location?
Discussion in 'Water Heater Forum, Tanks' started by Wallijonn, Apr 17, 2014.
  1. Wallijonn
    Wallijonn Member
    Jun 7, 2013
    computer technician
    Arizona
    Is it possible to re-locate the temp/pressure valve from the side to the top? I like the Kenmore/A.O. Smith WHs but they have the pressure relief valve on the side. One of the features on a WH that I am interested in is minimal lime buildup within the WH. (To that end I am thinking of installing two sediment filters in line with a third charcoal filter before going to the WH.) My present WH is probably a Rheems and while the TPR is located at the top of the unit it also has what looks like a hex head bolt head on the side, perhaps suggesting that the TPR can be re-positioned. Can that be done on the Kenmores?
Similar Threads: Temperature Pressure
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Proper temperature of boiler water going into Super Stor Oct 8, 2014
Water Heater Forum, Tanks Shower hot water temperature occasionally warm (not hot) Jul 23, 2013
Water Heater Forum, Tanks Air temperature affecting expansion tank air psi Dec 8, 2012
Water Heater Forum, Tanks Water heater not at correct temperature at random times. Occurs inconsistently. Jan 29, 2011
