Teledyne spa heater wont fire in damp weather
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chillywilly, Sep 28, 2005.
  1. chillywilly
    chillywilly New Member
    Sep 28, 2005
    I have a 10 year old Teledyne Laars Series 2 type ESC heater installed outdoors and used as a spa heater. During dry weather it works great. When it is damp, the pilot ignites and stays lit, but the burner will not fire. There is a buzzing sound like the pilot igniter that continues indefinately. A few hours after the sun comes out, its back to normal. Any suggestions besides moving to a sunny climate?
  2. hj
    spa
    Loosen and then retighten the screws on the thermostat, or remove the wires and clean the contacts on the thermostat and wire terminals.
  4. chillywilly
    Sep 28, 2005
    Thanks, I'll give it a try this week end and post results.
Similar Threads: Teledyne heater
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
Plumbing Forum, Professional & DIY Advice Water takes forever to heat up and it's close to the water heater Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Small hot water heater solution? And related drainage question... Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
