Technetic 1000
Discussion in 'Water Softener Forum, problems, installation and r' started by rpansing, Aug 7, 2009.
  1. dalp
    dalp New Member
    Jan 7, 2010
    canada
    technetic programing
    the 9900 that you see should be 9999 which displays after you have set the time of day or salt dose or hardness.
    did the 9900 ( or 9999 ) remain on the display or does it show another value?
    If it still shows 9999 on the display it will not countdown until you have used up enough water to drop it below 9999.
  2. steve1
    steve1 New Member
    Dec 30, 2009
    Michigan
    Technetic 1000 Programming
    Dalp,
    The 9900 shows up when I press the time and enter buttons together for 5 seconds. It stays on the screen until I unplug and replug the unit back in to get out of this programming mode, as I have yet to figure out how to exit this mode. Once I plug the unit back it, it goes back to the messed up clock display. The gallons remaining doesn't decrement either.
    Steve.
  3. dalp
    dalp New Member
    Jan 7, 2010
    canada
    i messed around with my control and got the 9900 to come up. i kept pushing buttons and could put up any number on the screen that i wanted but only after the numbers went through some ` weird shapes ` . i unplugged it and it went back to the clock when plugged in with 2 dots...one for pm and one above the minutes. I wonder if that ` menu` is for sizing the control to the tank when it is built.
    Do you have the info for setting your hardness an salt an time ?
  4. steve1
    steve1 New Member
    Dec 30, 2009
    Michigan
    Ya, Here is the manual for the unit. It walks you through the steps to program everything. The only problem is, it doesn't mention anything about this weird mode.
    http://www.reynoldswater.com/activek_apps/rwc/assets/manuals/tn.pdf
    I hope that we can figure this out together. Your display sounds exactly like mine now. Does your gallons remaining advance automatically anymore?
    Steve
  5. dalp
    dalp New Member
    Jan 7, 2010
    canada
    i have tried changing numbers in this weird mode and think i have it totally messed up, and i havent found a way out of the mode yet other than unplugging it an plugging it back in. After doing that it goes back to the clock with no problem. Mine will count down with no problem although i am starting to have a problem with it stalling occasionally in the backwash mode.
    have you tried manually regenerating or test regenerating to see if it affects the control?
  6. Gary Slusser
    Retired
    This won't get any better if the circuit board is bad.
  7. steve1
    steve1 New Member
    Dec 30, 2009
    Michigan
    I have tried regenerating manually and the gallons remaining just displays 1697 without counting down. It manually regenerates without stalling however. When you exited the programming mode, did your display have the 9999 showing or was it 9900 like mine? There has to be something to do in that mode to get it back into automatic countdown. I think that is where my problem lies if only this mode was a bit more descriptive rather than weird characters I would be able to stumble around there and correct the problem. I mean we can't even figure out how to exit the mode, which leads me to believe that there is a sequential procedure that has to be followed the unit will probably exit this mode automatically and restart.
  8. nbpetri
    nbpetri New Member
    Jun 30, 2010
    Framingham, MA
    Technetic 1000 revisitied
    We have a running T-1000 unit from 1995 and seems to be working OK, in my mind. The local co came by and suggested that the ion exchange was less efficient now and that we should get the new Avantapure system, another $2k.
    50% less salt via a 'counter current regeneration process???
    Supposedly too that the proportional brining is more efficient today.
    The T-1000 also had proportional brining.
    I am not convinced we have a problem. Do you think there is technology advancement with controls that might apply or be worth considering?
    Do these ion exchange units need to be changed after 15 years or is it better to simply upgrade the system with something new?
    Thanks for your help Nick P- MA
  9. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    Tough call. Depends on if you can do the resin change or have to have it done. It will be less expensive than changing out the whole unit but on the other hand, if your luck runs like mine does the unit will crap out 6 months after you sink a grand into it.
  10. Gary Slusser
    Retired
    Unless they fully regenerated the resin bed and then found hardness getting through the bed, you don't need a new softener or resin. They are just trying to sell new equipment.
    The Avantapure (269 valve and 263i IIRC timer) has the same features as the 1000 although it is an industry standard type of control valve where the 1000 was a unique design. Resin should not be replace on a time basis, only when it is not capable of removing all the hardness.
Similar Threads: Technetic 1000
Water Softener Forum, problems, installation and r Technetic 1000 Jan 11, 2010
Water Softener Forum, problems, installation and r Technetic 1050 PP draw question(s) Oct 4, 2011
