Tape / dope on braided supply lines?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DavidTu, Oct 1, 2011.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    I thought I'd seen on the forum to NOT put pipe dope and/or plumbers tape on braided supply line connections... but now I don't find the reference. In any case... do these connections take dope or tape? My faucet instructions call for it but I've installed them w/o leaks and without tape or dope previously.
    What is best practice on this?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Many of the braided hoses now have O-ring seals and as such don't need to be doped. If they use a metal to metal seal, a little pipe dope is fine but I would never use tape. IMHO tape is for sealing threads and on those hoses the threads don't do the sealing.
  4. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    If it's a compression fitting, you don't use tape or dope.
    The compression ring/ferrule seals the joint, over tightening is also bad news.
    Tape and dope are for TAPERED threads, where the threads do the sealing.
  5. jimbo
    jimbo Plumber
    Braided supply lines normally have a rubber gasket seal...tape would intefere. Some brands use a 'bullnose' which simulates an actual compression ring. It is for metal-to-metal seal, and again, NOT tape or dope
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    THe problem with the bullnose is that it is of a much harder metal and so does not truly simulate a compression ring, which as the name implies, compresses to seal not only against the tube but also against the machined tapers. Any imperfection in the machined faces can cause a leak.
Similar Threads: Tape dope
Plumbing Forum, Professional & DIY Advice Shower Drain - thread in or tape/dope? Dec 11, 2015
Plumbing Forum, Professional & DIY Advice Tape or Dope on Old Propane Stove Connection Jun 22, 2014
Plumbing Forum, Professional & DIY Advice 3/4" Copper UNION - Use Teflon Tape or Pipe Dope? Feb 29, 2012
Plumbing Forum, Professional & DIY Advice Slip-joints & teflon tape / pipe dope Sep 9, 2011
Plumbing Forum, Professional & DIY Advice Pipe Dope, Plumbers Putty, or Teflon Tape? May 3, 2008
