tankless water heater
Discussion in 'Tankless Water Heater Forum' started by r_harper, Dec 29, 2008.
  1. r_harper
    r_harper New Member
    Dec 29, 2008
    I have a few questions about tankless water heaters. My parents were considering installing one in their house when I realized a pontential alternate use for the heaters. I hope these questions fit the purpose of this site, as it is the only place where I can find people with the knowledge to answer my questions. I work on racecars that require the engines to be heated to about 160-180 degrees before they are started. The current engine heaters on the market cost 3500 dollars and I am trying to find a cheaper and better alternative. Could a tankless water heater be combined with a pump, mounted on a small cart and used to circulate and heat about 2 gallons of water? Could they heat the water to those temps if the temperature safety switch was removed? Could they withstand temps that high? Could a 110 or 220 v generator power one? Is there a particular model that would work best? Any help is appreciated.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I could see a cart with one of those small propane tanks working one of these.
    Of course, that's probably a $1500 idea to make it work between a small tank, tankless heater and propane tank.
    If they made a tankless heater without the use of electric to operate the controls, you could have something to sell to other race car drivers. $$$$
    Money shouldn't be the objective in this since racing is an expensive endeavor...post pics when you get one together!
  4. Probedude
    Probedude New Member
    Nov 25, 2008
    CA
    Take a look at those heaters used in mobile car detailing and truck mounted carpet cleaning rigs. I can't remember the name and couldn't find anything on google quickly but from what I remember they're essentially a tankless setup - coils of tubing in the flame path. From what I've seen they're propane powered and self contained, oh and also can reach over 200 deg F. Can probably pick one of these up cheap on the used market.
  5. r_harper
    r_harper New Member
    Dec 29, 2008
    Thanks for the ideas! I was picturing an electric heating element setup and hadn't really imagined using propane, but a gas heater might work out. I'll post whatever I come up with.
  6. hj
    heater
    An electric heater would need a 240v generator, and possibly 10,000 watts, depending on the heater's capacity.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Here's an article recently posted by another forum user.
    This is out of Consumer Reports.
    Heating water accounts for up to 30 percent of the average home's energy budget. Some makers of gas-fired tankless water heaters claim their products can cut your energy costs up to half over regular storage heaters. So is it time to switch?
    Probably not. Gas tankless water heaters, which use high-powered burners to quickly heat water as it runs through a heat exchanger, were 22 percent more energy efficient on average than the gas-fired storage-tank models in our tests. That translates into a savings of around $70 to $80 per year, based on 2008 national energy costs. But because they cost much more than storage water heaters, it can take up to 22 years to break even—longer than the 20-year life of many models. Moreover, our online poll of 1,200 readers revealed wide variations in installation costs, energy savings, and satisfaction.
    With the help of an outside lab, we pitted Takagi and Noritz gas-fired tankless water heaters against three storage water heaters. EvenWe didn't test electric tankless heaters because many can't deliver hot water fast enough to replace a conventional water heater if ground*water is cold. in areas with warm groundwater, most homeowners would need to upgrade their electrical service to power a whole-house tankless model.
    Our tests simulated daily use of 76 to 78 gallons of hot water. That's the equivalent of taking three showers, washing one laun*dry load, running the dishwasher once (six cycles), and turning on the faucet nine times, for a total of 19 draws. While that's considered heavy use compared with the standard Department of Energy test, we think it more accurately represents an average family's habits. We also ran more than 45,000 gallons of very hard water through a tanked model and a Rinnai tankless model to simulate about 11 years of regular use.
    Here's what else we found:
    Water runs hot and cold
    Manufacturers of tankless water heaters are fond of touting their products' ability to provide an endless amount of hot water. But inconsistent water temperatures were a common complaint among our poll respondents. When you turn on the faucet, tankless models feed in some cold water to gauge how big a temperature rise is needed. If there's cool water lingering in your pipes, you'll receive a momentary "cold-water sandwich" between the old and new hot water. And a tankless water heater's burner might not ignite when you try to get just a trickle of hot water for, say, shaving.
    Nor do tankless water heaters deliver hot water instantaneously. It takes time to heat the water to the target temperature, and just like storage water heaters, any cold water in the pipes needs to be pushed out. And tankless models' electric controls mean you'll also lose hot water during a power outage.
    Up-front costs are high
    The tankless water heaters we tested cost $800 to $1,150, compared with $300 to $480 for the regular storage-tank types. Tankless models need electrical outlets for their fan and electronics, upgraded gas pipes, and a new ventilation system. That can bring average installation costs to $1,200, compared with $300 for storage-tank models.
    Tankless units might need more care
    During our long-term testing, an indicator on the tankless model warned of scale buildup. We paid $334 for special valves and a plumber to flush out the water heater with vinegar. Many industry pros recommend that tankless models be serviced once a year by a qualified technician. Calcium buildup can decrease efficiency, restrict water flow, and damage tankless models. Experts suggest installing a water softener if your water hardness is above 11 grains per gallon. Ignoring this advice can shorten your warranty.
    Efficient storage models are pricey
    We also tested the $1,400 Vertex, a high-efficiency storage water heater by A.O. Smith. The manufacturer claims its installation costs are similar to a regular storage model. But its high cost offsets much of the roughly $70 per year the Vertex will save you. Instead, we recommend buying a conventional storage water heater with a 9- or 12-year warranty. In previous tests, we found that those models generally had thicker insulation, bigger burners or larger heating elements, and better corrosion-fighting metal rods called anodes.
    Posted: September 2008 — Consumer Reports Magazine issue: October 2008
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
  9. Eagle45
    Eagle45 New Member
    Jan 1, 2009
    Coleman portable demand heater
    You might consider a Coleman portable on-demand heater. These are about the size of a beer cooler & you just hook it to portable propane tanks. I belong to a service club & we use one to provide hot water for a food catering venture we operate. Seems to work pretty good & only cost about $300. Very handy, hot water anywhere
    http://www.coleman.com/coleman/colemancom/detail.asp?product_id=2300A700
Similar Threads: tankless water
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
Tankless Water Heater Forum Tankless Water Heater Cleaning Solution? Mar 7, 2017
Tankless Water Heater Forum Descaling a tankless water heater Mar 4, 2017
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Tankless heater house...Kitchen has no hot water, bathroom has plenty Nov 24, 2016
