camner
- Messages
- 5
- Reaction score
- 0
- Points
- 0
One of the issues with a tankless system is the so called "cold water sandwich."
I'm intrigued by the idea at the end, which is to install a pump between the tankless and the tank so that the tank is filled by the tankless heater when the thermostat on the tank indicates that it needs to have hotter water. See "The Fix: problem #2" in the PDF)
I don't understand the plumbing diagram for this, though. It appears to use 3 inlets into the tank, when I think there are typically only two.
Has anyone tried anything like this out? Or even if not, to explain how the pipe diagram would work?
