Tankless water heater question
Discussion in 'Tankless Water Heater Forum' started by pagemap, Dec 9, 2008.
  1. pagemap
    pagemap New Member
    Dec 9, 2008
    Minneapolis, MN
    Hello,
    I am considering going "tankless" with a Rheem RTG-66XN, which is an outdoor gas-powered tankless water heater. I live in Minnesota, and I'm interested in the outdoor unit primarily so that the unit won't consume the indoor air that I paid to heat or cool, I'd rather it consume outdoor air and so I don't need to run new venting.
    • What is the typical installation cost for an outdoor tankless unit?
    • Where would people typically install the tankless unit? Is it built to be directly exposed to the elements?
    • Rheem says their heaters are safe to -30F. Can anyone comment how it's freeze protection works?
  2. Ladiesman271
    Ladiesman271 Homeowner
    Aug 22, 2008
    Care and maintenance of transformers
  4. jimbo
    jimbo Plumber
    San Diego, CA
    What is your demand for hot water. Note that in your Minnesota winter, where you will need at least 70º rise to get barely hot enough for a shower, the flow is only about 4 GPM, and if you wanted 80 or 90º rise, your max flow will be even less.
  5. gregsauls
    gregsauls Homeowner
    Nov 10, 2008
    IT
    Texas
    My indoor Rinnai R75 uses outdoor air for combustion. The single vent to the outside has an inner steel pipe for exhaust gas out, and an outer pvc pipe for combustion air into unit. All in a 5" tube.
Similar Threads: Tankless water
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
Tankless Water Heater Forum Tankless Water Heater Cleaning Solution? Mar 7, 2017
Tankless Water Heater Forum Descaling a tankless water heater Mar 4, 2017
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Tankless heater house...Kitchen has no hot water, bathroom has plenty Nov 24, 2016
