Tankless water heater cold water line
Discussion in 'Tankless Water Heater Forum' started by prbearden, Feb 1, 2012.
  1. prbearden
    prbearden New Member
    Feb 1, 2012
    rockport, tx
    Greetings,
    When installing a whole house tankless water heater (electric, if it matters) do I need to take the cold water input directly off the meter or can I connect to any cold water pipe in the house?
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    YYou can pretty much take the cold feed from anywhere, but you'll get less pressure drop/higher flow if you run it direct to the meter with 3/4" line. But that may not be the limiting factor to hot water performance, particularly with an electric tankless, since high flow rates are out of the question due to the comparatively low heat-input capacity of an electric HW heater.
  4. prbearden
    Feb 1, 2012
    rockport, tx
    Thanks, Dana!
Similar Threads: Tankless water
Tankless Water Heater Forum New to tankless water heater and can't figure it out! Mar 16, 2017
Tankless Water Heater Forum Tankless Water Heater Cleaning Solution? Mar 7, 2017
Tankless Water Heater Forum Descaling a tankless water heater Mar 4, 2017
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Tankless heater house...Kitchen has no hot water, bathroom has plenty Nov 24, 2016
