tankless vs boiler
Discussion in 'Tankless Water Heater Forum' started by essentialagenda, Aug 25, 2008.
  1. essentialagenda
    essentialagenda New Member
    Aug 21, 2008
    Hi,
    can someone tell me what the difference is between a wall hung tankless water heater and a wall hung boiler? and when would one use one vs the other?
    thanks
  2. jadnashua
    A tankless system is designed for producing potable hot water instead of a conventional water heater. A boiler is designed to provide heat to a dwelling. A side benefit is the ability to heat a tank of water using a zone and an indirect water heater tank.
    A tankless system, because it is heating water as it passes through and then dumped down the drain, won't get the water hot enough for many space heating purposes. A boiler, because it can recirculate the water is able to produce much hotter water, typically required for radiators.
Similar Threads: tankless boiler
Tankless Water Heater Forum Tankless oil-boiler water heater vs. other options? Apr 11, 2014
Tankless Water Heater Forum Thoughts On Navien Vs AO Smith Small Tankless Propane Boiler Mar 12, 2014
Tankless Water Heater Forum New tankless boiler coil question Jan 6, 2013
Tankless Water Heater Forum mod con tankless combo NG boiler sizing to exisiting cast iron radiators Feb 20, 2012
Tankless Water Heater Forum bypass tankless in smith water boiler Nov 27, 2011
