Tankless heater help on install .....
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GoingTankless, Apr 24, 2006.
  1. GoingTankless
    GoingTankless Plumber
    Apr 23, 2006
    NJ
    I have been asked by a few, what to do to fix the problems with tankless heaters but lets start where we should.
    Installation....there are a few factors needed to address for the right installation.
    Location: You want to get it as close to the demand as possible.
    Venting: Keep it as short as you can to keep down the cost and it's effiency up.
    Gas supply: It is very important to size the system properly. NEVER use a gas flex to connect to the unit. Hard pipe if you can. If you choose to use flexable gas pipe like GASTITE always check you calculations you usually have to upsize. Standard gas flex you use on a stove or a dryer will NOT work.
    Water condition: Make sure the quality of the water in the home or commercial building is correct. Have it tested. It does make a difference
    These simple steps will save you a lot of headaches. Whether you have a tank or tankless the condition of the water is critical in the life of your plumbing system and appliances.
    Use the proper service valves. they make life easy if there is ever a need to use them. Remember it will likely be you to service what you install.
    http://boschhotwater.com Its not for advertisement its for education. There is a lot of info that can help you in your decision. For my fellow proffesionals go to http://protankless.com/ Most of your question will be answered there.
    If you need help just ask........I'll be glad to help you
Similar Threads: Tankless heater
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Time / Distance tankless water heater Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Bosch Aquastar tankless 1600 water heater firing up on it's own Aug 22, 2016
Plumbing Forum, Professional & DIY Advice State Tankless Water Heater help please! Oct 30, 2015
Plumbing Forum, Professional & DIY Advice Gas or Electric Tankless Water Heater? Jul 29, 2015
