tankless and point of use unit for diving application
Discussion in 'Tankless Water Heater Forum' started by comdiver, Jan 30, 2014.
  1. comdiver
    comdiver New Member
    Jan 30, 2014
    Tennesse
    I am a commercial diver looking to install hot water delivery system in a compact electrical way on my boat to to supply hot water while working in a body of water ex: river - If I install a tankless unit with a pump to feed water to inlet what is the flow rate needed for delivery to inlet side? I will then feed a 7 gallon point of use from the tankless. The point of use will then go through a hose to deliver hot water to me while in sometimes very cold water working for sometimes an extended amount of time. The tankless should supply endless hot water to the 7 gallon "reserve" point of use tank that will deliver hot water. Any specs for delivery pressures to either tank? Any pros want to jump in and give me feed back? Go!
  2. cbytes
    cbytes New Member
    Dec 1, 2013
    montana
    First off I would use a LP (propane) tankless unit and hook up a 100# bottle to it and use a boiler feed pump (120 volt) (you might find a 12 volt pump to supply .5 gallons per minute it needs at an RV store) to get flow to it, making sure inlet is filtered against debris. Hot water supply will only be endless until power fails or propane runs out.
    Second watch all the episodes of Bering Sea Gold, they have already designed the diver hot water systems.
    Third if you strike it rich, don't forget us little guys.
    Fourth, if you ever need a deck hand for fame and fortune, I am a 6 year US Navy Nuclear Engineer, they called me "The Designer".
Similar Threads: tankless point
Tankless Water Heater Forum Switch from Tank to Multiple Point-of-Use Tankless, Crazy? Oct 15, 2009
Tankless Water Heater Forum Tankless water heater: Point of use Apr 10, 2008
Tankless Water Heater Forum Tankless water heater with a small tank? Feb 3, 2017
Tankless Water Heater Forum Bosch us12 tankless Jan 27, 2017
Tankless Water Heater Forum Tankless issues Jan 24, 2017
