Michelle-YYZ
Hi
Hoping someone can confirm or refute a possible solution.
New 3/4hp jet pump (shallow well), New 81gal (yes, greedy) pressure tank. Switch set 20/40.
output from pump is 1", intake to tank is 1-1/4". Output from tank stepped down 1-1/4" to 3/4".
Lots of water to pull from. Line is in the lake, 6' depth. Gage appears accurate - slow gentle pressure loss when opening taps. Run the pump, the pressure climbs to 30-32 lbs MAX and will climb even is running water elsewhere (laundry, bathroom).
Pressure tank just wont climb above about 30lbs - therefore pump doesn't make it to the cut-out pressure.
Could it be the pressure tank just isn't getting enough volume of water because of the 1" line? If I increase my line to 1-1/4" - think that might resolve the issue?
Never had any issues with a 1/2 hp jet pump and 20 gal pressure tank combo.
Stumped. Nobody reputable in my area to reach out to. Hacks with less skill than we have.
