Tank water heater- dielectric union? heat trap?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by edwardh3, Nov 23, 2008.
  1. edwardh3
    edwardh3 New Member
    Jan 5, 2008
    South Carolina
    Replacing a 40 gal electric water heater that now is connected by flex copper. The general installation instructions on the Love Page for water heater replacement do not mention heat traps - either loops or nipples. If you use flex copper lines, how much "loop" heigth do you need- do you need it on both hot and cold lines? and do you need a dieelectric nipple coming out of the tank?
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    heat traps
    depending on the brand of theater you buy,
    it might already have a heat trap build into the niples comming out of the top of the heater.....
    I personally like the brainded flex connectors
    they work much better than dia-electric unioins
    I suppose if you buy a couple of 24 inch long ones
    and make a loop it would make a heat trap
  4. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    In Illinois the flex pipe are not allowed. It must be hard piped in with unions. Now if your using copper they prefer you to use dielectric unions, or solid brass unions to connect the indifferent metals.
Similar Threads: Tank water
Plumbing Forum, Professional & DIY Advice Where to place Tankless Water Heater Condensation Line Mar 22, 2017
Plumbing Forum, Professional & DIY Advice Getting a tankless water heater installed, but have questions on piping size Mar 6, 2017
Plumbing Forum, Professional & DIY Advice Kitchen faucet not working after flushing tankless water heater Mar 4, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
Plumbing Forum, Professional & DIY Advice Calculations for tankless water heater gas supply Jan 6, 2017
