Tank type or electric tank-less?
Discussion in 'Water Heater Forum, Tanks' started by Just some guy, Jan 24, 2013.
  1. Just some guy
    Just some guy New Member
    Jan 24, 2013
    Plumbing designer for MEP engineering firm.
    Georgia
    Opinion question for all installing contractors:
    Given a small retail space with two restrooms, one lavatory with a 0.5 gpm faucet flow rate in each, would you prefer to use a single, roughly 6 to 8 kw tankless water heater such as Eemax or Chronomite, or a 6 gallon tank type heater mounted above the ceiling? Co-worker tells me contractors tell him tank type is the cheaper way to go. I find this hard to believe given a tank type would require a platform, drip pan, expansion tank or relief valve, hub drain to run the drip pan drain line to, and most likely a trap primer to keep the hub drain from drying out. Not to mention you would have to perform this work on a ladder.
    If it were you, what would you do?
    Thanks to all who respond.
Similar Threads: Tank type
Water Heater Forum, Tanks Which type of gas water heater tank makes the most sense (venting related question) Dec 18, 2013
Water Heater Forum, Tanks HW Heater to tankless coil Feb 13, 2017
Water Heater Forum, Tanks Anode Rod Aluminum broken in two; can't get rod out of tank! Feb 11, 2017
Water Heater Forum, Tanks Low amperage, lowest cost point of use electric water heater tank for low volume use? Jan 31, 2017
Water Heater Forum, Tanks Expansion Tank, and other water heater questions.......... Jan 28, 2017
