Dave Stone
My sister's 2-piece toilet "runs" at intervals, indicating a leak from the tank to the bowl (no sign of exterior leak). I replaced the flapper with a new one and all seemed well, but she says the leak hasn't stopped. She says applying downward pressure on the new flapper (using her hand) stops the leak.
Did I buy a bad flapper (Certain Seal, #400)? It was identical to the original, and the gasket looked OK, but so did the gasket on the one I replaced. There is slack in the chain when the flapper is seated.
The seat on the flush valve looked OK and had no visible build-up of crud and felt smooth to my finger.
Can flush-valve seats warp over time? The toilet (1.6 gal/flush) is, I think, at least 15 years old. Is it time to replace the flush valve?
Is there another way the flush valve can leak into the bowl that might be stopped with hand pressure on the flapper? As you can tell, I'm a little unclear about the structure of the valve and its gaskets.
Thanks.
Dave
Thanks.
Dave
