Tank from 1948 replace ?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Snoozo, Jan 20, 2014.
  1. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    New guy here. Bought my house bout 5 years ago and have been adding air as needed. Last week the start cap blew in the control box and started me investigating the system. I realize I have no info on the pump or the well. I think I have 12 Gpm but that's all I know.
    New relay and cap installed and all is good again,but now I'm starting to think I might want to replace with a diaphragm tank.
    What do you think?
    Have you guys ever seen a tank fail catastrophic and flood a basement for 8 hours? Could this happen?
    I think this tank is from 48 when house was built,ever seen a tank with the glass tube on the side?
    I am one for keeping older better quality stuff alive cuz I realize what we have today fails in comparison tremendously. But 1948? Water tank?
    Been thinking about a cycle valve and small tank but have no idea what condition my pump and motor are in so I'm very hesitant and probly would put in a 44 gal tank and call it a day.
    No way I'm pulling the pump anytime soon
    Also have read that air over tanks are good for iron rich wells which I assume I must have due to the iron curtain installed.
    Amp draw is around 5.25 run winding and 12gpm is this a 3/4 hp. Can you tell?
    One other thing I have considered is leaving this tank in place but putting a pressure tank next to it.
    My question is if I pipe them together and let the original water tank go waterlogged would that increase my drawdown of the pressure tank and whole system in turn?
    Then I wouldn't have to worry about charging the original tank all the time as I think there is no bleeder in the well,no air control provision on the tank and the check valve that is at the well head in the pit does not appear to have any way to suck air. It's just a solid brass check.
    Any opinions welcome
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If it ain't broke, don't mess with it.
  4. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Galvanized tanks corrode from the inside out so that relic is probably paper thin in places and just waiting for an opportune time to start leaking, most likely Super Bowl Sunday, high school graduation, 4th of July......
    My advise is to replace it yesterday.
  5. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    My gut says I should replace it but when I look at how it's constructed and the gauge of the Steel ,I wonder. It has super thick walls and the welding around top,bottom and pipe openings is really quality and big.
    So I wonder could I add valves to inlet and outlet of old tank with a bypass added so that when it fails I can drain it and open bypass to pressure tank never losing water pressure to the house.
    I have floor drains in the basement and plenty of room for tank.
    Basement is not finished so no real worry about damage.
    Can I pipe it in series and let it waterlog is my only question,will it increase my drawdown or does it have to be pressurized?
  6. craigpump
    Apr 12, 2012
    By the time you chase for the materials, drain the tank and plumb up a bypass, you could have replaced the tank and not had to worry about it.
  7. Texas Wellman
    Texas Wellman In the Trades
    Feb 9, 2010
    Owner of a Water Well and Pump Repair Business
    SE Texas-Coastal
    I disagree. If it hasn't failed yet and the water quality stays the same it will probably last "forever".
    PS...people who switch from galv. tanks to bladder tanks often complain that the water now has an odor or taste that it didn't before. Just FYI.
  8. craigpump
    Apr 12, 2012
    Texas,
    Almost every galv tank I have replaced has failed from the inside out.
    He could install an FLS series fiber wound tank and have the best of both worlds, standard air over water configuration and a tank that won't corrode.
  9. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Do these galvanized tanks have anode rods like water heaters?
  10. Texas Wellman
    Feb 9, 2010
    SE Texas-Coastal
    If the water quality is OK it could conceivably last indefinitely. If it was going to fail it probably would have done so already. Even with today's low-quality galv. tanks they either fail within the first 20 years or never. You very rarely see a tank that is over 20 years old rust out.
    PS...we are about 90% galv. tanks in my part of the country. Almost every well I service has a galv. tank. I see dozens every week.
  11. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    No. Air gives you the drawdown. Less air = less drawdown.
  12. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I would speculate that it would be much like a water heater failure, where they can leak a little for for some time, but hardly ever will there be a catastrophic failure.
    The tank is made better than anything you can buy today. It's in an unfinished basement where nothing would be harmed it it does start leaking.
    Shut off your well pump when you go on vacation and enjoy life.
  13. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    No anodes that I can find. I have replaced a few anodes in my time for water heaters.
    At work we have some large commercial tanks in parallel and when we replace, the new ones come with aluminum rods as opposed to magnesium.
    We have Lake Michigan water around here that is treated and the ph is fairly high. Rods broke down very fast,sending small blue particles every where. (At least this was my best guess at what happened)
    Replaced with mag and no problems for couple years now.
  14. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    I see. I was under the impression that both tanks might draw down equal if in series. Effectively doubling the draw down of the pressure tank,but not giving you the full capacity of the larger volume un pressurized tank.
    I should have gone to college for physics:(
  15. Reach4
    Sep 25, 2013
    Two tanks will add their draw-downs. They don't have to be the same size or type.
    I would say that these tanks are in parallel, but I don't think there is a way to go wrong.
  16. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    Vacation what's that ?
    Ya the more I look at it I don't think there is much chance of catastrophic failure. This thing is "built like a tank"
    Got one seam that runs from top to bottom that's like 1/2 inch welding bead that's just perfect old school welding the whole way. I'm crazy for old American quality stuff.
    Feels like I'm going backwards to put in a modern bladder. But then the bladder is the convenience I'm looking for.
  17. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    So you think I would have the full load of this huge tank plus the bladder tank?
    I can't see how that's possible cuz you only have whatever the pressure is in the bladder to replace the exiting water. correct?
    Would seem like water from larger un pressurized tank would be replacing water leaving bladder tank until they equal off at some point. Which may be like when the tank levels are equal? Then the bladder would start to replace water and let the pressure drop on the gauge.
    Now I wonder is there a limit to the load a bladder can effectively have on it. So if I add this huge tank in series will I be overloading,with the weight of the water trying to push itself from big tank into small bladder tank ?
    I'm all messed up now
  18. Reach4
    Sep 25, 2013
    The pressure in the bladder will match the pressure of the water. As you add water to either tank, the air will compress. As you use water, the air pressure will become lower. The big difference is that if the water pressure becomes lower than the precharge pressure of the bladder tank, that tank no longer contributes water. However that will not normally happen,since the pump would go on before that point.
    I don't think the elasticity of the bladder is a big contributor under normal pressures. Once the pressure has risen to the pump cutoff pressure, the pressure stops rising. If the two tanks are roughly the same capacity, then each will act as if there was a pump pumping half as fast and the water is being used half as fast.They will share nicely. If one is the galvanized tank and if it has been totally waterlogged, then to the bladder tank in parallel it will be as if the galvanized tank is not there.
  19. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The OP was talking about letting the old tank get waterlogged in which case there is no air and therefore no drawdown. Without air it may as well not be there.
  20. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
  21. Snoozo
    Snoozo New Member
    Jan 20, 2014
    Illinois
    I do believe you may be correct. If I pipe the tanks in series I think the only way this would work is if I had a booster pump between the two tanks. Allowing the first tank (un pressurized storage) to pump into the bladder tank as it drains
    First tank would then have to be vented to allow air into it as water left. Otherwise it's like holding your finger over a straw and pulling out of a full glass.
    Only thing I stand to gain is a bunch of extra water stored.
    Now I have to think about parallel piping and if it's the same result. Probly is I just can't see it in my mind yet!
Similar Threads: Tank 1948
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
