Tank equivalent to Eljer 141-7000?
Discussion in 'Toilet Forum discussions' started by LowellMA, Jun 29, 2014.
  1. LowellMA
    LowellMA New Member
    Jun 29, 2014
    MA
    I need to replace my Eljer 141-7000 tank. Apparently these are rare, and I cannot locate one. Is there are way to find other tanks that could be used in its place? I believe the bowl is Eljer 131-7925 bowl.
    On the other hand, if you have a 141-7000 tank for sell, that would work also.
    Thanks Jeff
  2. Terry
    Aug 17, 2004
    Or you may want to pick up an American Standard Glenwall if you need a pressure assist wall hung toilet
    or the Gerber Maxwell wall hung with gravity flush.
  4. LowellMA
    LowellMA New Member
    Jun 29, 2014
    MA
    Thanks. I'll look at those after my search for a tank replacement fails; my toilet is partially cemented into the floor requiring much work to replace. --Jeff
  5. Terry
    Aug 17, 2004
    Is this a floor mount rear outlet?
    Or standard floor mount.
    And why would they cement a toilet to the floor?
    The old Eljer tank looks to be the Engergizer PF/2 that is no longer made, or perhaps an old Flushmate in there?
  6. LowellMA
    LowellMA New Member
    Jun 29, 2014
    MA
    This is a floor mount. I had the pressure units inside replaced with Flushmates, which work great. Unfortunately, one tank was bumped, and the tank cracked.
  7. Terry
    Aug 17, 2004
    Kohler Barrington with pressure assist
    American Standard Yorkville, pressure assist
    Gerber Maxwell floor mount rear discharge, gravity
Similar Threads: Tank equivalent
Toilet Forum discussions Wall concealed tank / floor mount toilet Mar 12, 2017
Toilet Forum discussions Proper Tank to Bowl Gasket on old Toilet Mar 1, 2017
Toilet Forum discussions Mansfield #160 tank Feb 27, 2017
Toilet Forum discussions Kohler Wellworth Cannister - Water won't fill tank (seal is new) Feb 20, 2017
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
