Tank air pressure for non bladder water tank
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by DonL, Jan 1, 2012.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    No gauge on the tank. Mine is mounted on the Pressure Regulator that controls the jet pressure.
    When the pump is off , I would think that it is reading the tank pressure.
    I could add another meter, but would have to worry about it freezing.
    I have a heat tape to keep the regulator and Pressure switch from freezing.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If you mount it high enough on the tank, it will be full of air so freezing would not be a problem unless you waterlog the tank. I have 3 gauges. My EPS15/99 shows the pressure via LED segment display, I have a gauge Tee'd off the switch, and I have a gauge Tee'd off the schrader at the top of the tank. All 3 read different. Chinese quality at its best.
  3. ballvalve
    Dec 28, 2009
    northfork, california
    Not so. But its a bit of an art to do a pre pressure with the water at the right level. AND count on it going down daily as the air absorbs into the water. If you have a 40 to 60 switch, and pressure to 35, you have about the same capacity as a bladder tank with its enormous draw down for cheap. the difference is the absorbtion and the fact that you loose all the air when the power goes out. Do it - tested it. works.
    But that is quite true. The float release is designed for submersibles.
Similar Threads: Tank pressure
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Wellpump and pressure tank mismatch? Jan 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Tank Jan 25, 2017
