Takagi TK3 Heating Intermittently
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jon.hillegeist, Feb 24, 2013.
  1. jon.hillegeist
    jon.hillegeist New Member
    Feb 24, 2013
    My tankless water heater is about 6 years old. We use it for radiant heat. I haven't used it much these season, but started too this week. At first the water pump would be on, but the water wasn't circulating. The water pressure gauge was at zero. I filled it up more, and now when it comes on, the water circulates and the pressure is about 15 psi.
    But, sometimes when it comes on and the water circulates, the heater doesn't ignite. If I flip the power off and then back on. a gurgle noise will come from the heater and it will turn on sometimes.
    Any thoughts?
    Thanks
  2. jadnashua
    It sounds like you have some air trapped in the pipes. This can cause an air lock. Does the system have an air extractor? If so, does it work?
Similar Threads: Takagi Heating
Plumbing Forum, Professional & DIY Advice Takagi TK3 hot water not working Jan 30, 2014
Plumbing Forum, Professional & DIY Advice Takagi Tankless W/H error code 1911? Jan 21, 2014
Plumbing Forum, Professional & DIY Advice takagi tk2 problem Aug 8, 2010
Plumbing Forum, Professional & DIY Advice Tankless H2O: Rheem vs. Takagi Feb 15, 2007
Plumbing Forum, Professional & DIY Advice Water softener Radiant heating question Mar 6, 2017
