Taco 006 BC4 Circulator pump running 24/7?
Discussion in 'Water Heater Forum, Tanks' started by scottall, Mar 17, 2010.
  1. scottall
    scottall New Member
    Mar 17, 2010
    CT
    Hi, the pump runs literally all the time and it has a bit of a rattling sound to it. Amd it is hot to the touch. And, the first shower of the day never gets truly hot. Is the pump failing? If I recall, the impeller was replaced once a long time ago. I would like to do it myself if that is what it needs. I understand the cartridge is easy to obtain and replace. If this is the correct path, can you guide me on stopping all water flow to the pump while I swap the cartridge and the O-ring? Thank you for any guidance you can provide.
  2. hj
    It is probably the pump. IF there are valves on both sides of the pump shut them off and replace the cartridge.
  4. scottall
    scottall New Member
    Mar 17, 2010
    CT
    Thanks for the reply. One line runs straight into the boiler and the other straight down into the hot water tank, no valves on either.
Similar Threads: Taco Circulator
Water Heater Forum, Tanks Circulator Help Dec 17, 2015
Water Heater Forum, Tanks Indirect circulator bad? May 5, 2011
Water Heater Forum, Tanks Circulator Sizing for Indirect Mar 6, 2010
