Table Lamp
Discussion in 'Electrical Forum discussion & Blog' started by Fudog, Dec 31, 2007.
  1. Fudog
    Fudog New Member
    Dec 31, 2007
    I have a table lamp that only works on the low setting. The bulb that is in it is a three way wattage type, any ideas what the problem could be? checked the bulb in another lamp and it works fine. I was wondering if maybe the switch is bad and at times if I touch it I will get a trickle charge of electric. It is unplugged now. THANKS!:confused:
  2. jadnashua
    Not all sockets are could just be an on-off switch.
    Most new lamps have a polarized plug...this puts the hot lead on the middle contact of the socket. Older ones, it's pot luck. If the insulation is worn or the wiring is frayed, or the socket is broken, you could have line voltage on the lamp body. If it isn't an expensive lamp, probably better to chuck it. If you want, you'll probably need to disassemble it and maybe rewire. Don't plug it in until you've checked it out - it could kill you.
    If you have a multimeter, you can check to see if you have continuity between either prong of the plug to the body of the lamp...if you do, fix it.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    North Carolina
    It is time for a new lamp.
  5. 480sparky
    480sparky In the Trades
    Oct 8, 2007
    I'm in the 'it's not a 3-way socket' camp. Pull the bulb out and look inside the socket. If there's two connections, it's a 3-way. If there's one, it only takes a standard bulb.
    You can either install a standard bulb, or change the socket to a 3-way. It's easy to do... just make sure the part of the cord that has the ribs on it go to the silver screw.
Similar Threads: Table Lamp
Electrical Forum discussion & Blog Exceptable voltage levels for 120V? Aug 15, 2016
Electrical Forum discussion & Blog Can I plugin a 240V into a 250V receptable? Apr 19, 2016
Electrical Forum discussion & Blog Need a solution for portable generator and panel. Nov 21, 2015
Electrical Forum discussion & Blog hook up of table saw Jan 12, 2013
Electrical Forum discussion & Blog Help eliminating glare on worktable from overhead fixtures Dec 15, 2012
