T-wye or Sani-t on 3" secondary stack
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by burked1234, Jan 24, 2011.
  1. burked1234
    burked1234 New Member
    Jan 21, 2011
    Pittsburgh, pa
    Hi-
    What is the correct piece to use on a 3" vertical secondary stack. I am adding in the plumbing from my washer to this. it currently has a cleanout T on it, which will be moved up to make room for this. i would prefer to use the Sani-t since it will add less height to the plumbing but can make the T-wye work.
  2. Terry
    Aug 17, 2004
    You can use a santee on the vertical. Just make sure you vent the washer between the stack and the p-trap.
  4. burked1234
    Jan 21, 2011
    Pittsburgh, pa
    Yep. I believe the vent needs to be less that 60" from the p-trap to the vent correct?
    I know that AAV's are hotly contested. i was thinking about using one in the application, and coult *possibly* get it routed to the outside. Any throughts on this?
Similar Threads: T-wye Sani-t
Plumbing Forum, Professional & DIY Advice Sani-tees horizontal all over the place on house lift project NJ Monday at 8:33 AM
Plumbing Forum, Professional & DIY Advice Minimum distance from trap to sani-tee Mar 26, 2011
Plumbing Forum, Professional & DIY Advice Make chrome trap to sani-T connection look nice Jun 22, 2005
