System won't shut off
Discussion in 'Irrigation / Sprinkler Forum' started by Yarbs02, Mar 27, 2012.
  1. Yarbs02
    Yarbs02 New Member
    Mar 27, 2012
    Detention Deputy
    Canon City, CO
    I have a system, not sure what brand, was already here when I bought the house.
    Went to get setup for the spring/summer, had to replace the PVB. Got that all squared away, turned the system on for the first time, ran through zone 1 cycle just fine, zone 2 cycle didn't have as much pressure, then shut off zone 1 came back on and won't shut off unless I close the water valve to the system. Reset the timer, unplugged the timer, turned water on, zone 1 came on, sone 2 is not on at all...
    Need some help to figure this thing out...
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    it sounds like the zone 1 valve needs to be rebuilt or replaced. I usualy see this problem when a diaphram goes bad or a lot of debris has got into the valve.
  4. Yarbs02
    Yarbs02 New Member
    Mar 27, 2012
    Detention Deputy
    Canon City, CO
    For those of you that might have the same problem here's what I did.
    I took the cap and diaphragms off the selnoids and blew them out, made sure there was no debris stuck inside and made sure they got a good seal... Tried the system again... Everything works fine.
  5. jimbo
    jimbo Plumber
    Pretty much that is what we would have recommended!
Similar Threads: System won't
Irrigation / Sprinkler Forum Sprinkler system won't start Oct 12, 2008
Irrigation / Sprinkler Forum Water Master drip system that won't stop running Jun 7, 2007
Irrigation / Sprinkler Forum Flow required to properly blow out sprinkler system Oct 22, 2016
Irrigation / Sprinkler Forum Reviving Old Irrigation System Oct 9, 2016
Irrigation / Sprinkler Forum Inground sprinkler system SPLITTER? Sep 8, 2016
