Switch with GFI
Discussion in 'Electrical Forum discussion & Blog' started by Homeownerinburb, Mar 26, 2013.
  1. Homeownerinburb
    Homeownerinburb Member
    Jan 14, 2012
    Los Angeles, CA USA
    This is probably one for Leviton. I have never seen this, have you?
    I'd like to have in one strap a GFI with a rocker switch, but no outlet.
    I'd like to see the switch be the same size as one of the switches in a tandem decoura switch. The GFI buttons could be below it.
    I'll be installing a fan/light in a shower stall and am looking for the easiest and cleanest look. The switch box will have a second strap with three switches on it, for another fan/light/heat rig. The light switch on that one will also control the vanity light.
    There is no useful purpose in a receptacle at the door, and the narrow switch which is typical will stand out.
    Anyone have a lead?
    Again, I expect that it just does not yet exist.
  2. jadnashua
    There are wire in GFCI devices without any component (i.e., switch or receptacles) and of course, you could always install a GFCI CB in the panel, but then, if it trips, it isn't as convenient (but in a well designed system, it may never trip).
  4. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Yes, a blank face gfi exists, but I don't want to put in three straps if I could help it. And I'd as soon not put in a gfi breaker, even though it would be right across the hall in a sub panel. The house dates back to the late '40's and I am dubious of what the wires would do being down stream of a GFI breaker. I imagine all sorts of trouble with that.
  5. jadnashua
    If the panel has room (and you can find a GFCI breaker that fits!), being right across the hall may mean a new run wouldn't be too bad.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The Leviton Decora listings show a single rocker switch over a single receptacle with GFCI buttons in the middle. Don't see anything without a receptacle.
  7. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Yes. I understand.
  8. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    The inspector will insist on Arc Fault with any new circuits.
  9. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    not for a bath
  10. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    It never hurts to ask.....but yes, I think you are correct on that one.
  11. hj
    What would the GFCI monitorl if there were no outlet?
  12. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    You should contact them and have them make a special one for you.
  13. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Right after I start to lay golden eggs.
  14. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    The fan/light combo in the shower stall, which the manufacturer and my inspector want to have on a gfi.
    My inspector is ok with me using the vanity gfi for this, now I just need to get up in the attic and see how the conduit runs.
  15. hj
    If you are lucky, the feed could go to the GFCI receptacle first and then to the switch. If so, all you would have to do is change the wire from the line side to the load side.
  16. jadnashua
    As with any GFCI, anything wired on it's load side...anything you deem desirable or required.
  17. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    I got into the property today. The vanity receptacle and the lights are on two different circuits, the vanity conduit passes nowhere near the light switch.
  18. jadnashua
    If you don't want to add a GFCI in the box, or at the panel, you could still add one of the blank face ones in an out of the way location, as long as it was still accessible. Never know, you may want to plug in a vacuum or steam mop or something, and having a 'normal' one near the floor somewhere may be a convenient item.
  19. Homeownerinburb
    Jan 14, 2012
    Los Angeles, CA USA
    Actually, there is an evil genius in that. The hall is quite long.....without an outlet. What would be SO cool is that I could lift the power from the lights in the bath. Ooohh. I feel some wood coming on.
Similar Threads: Switch
Electrical Forum discussion & Blog Transfer switch connections Wednesday at 10:44 AM
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Sunday at 6:17 AM
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog 4 way switch multiple lights Feb 8, 2017
