Sweet smell coming off of baseboard heaters
yarrow
Washington
these are way old (50's?) copper tube and flange hot water baseboard units in an apartment that i just moved into. the longer i run the units, the higher the setting, the stronger the smell, kind of a chemical sweet smell. i've totally soaked/cleaned them with non-toxic cleaner, so that they're completely shiny/like new, but still get the odor when i turn them on/leave them running.
i notice if i turn the units down to 60 at nite, they'll kick in early morning and i wake up with chest pain, sore throat, smelling that sweet odor and my cat does a wierd thing with his mouth, like he's got something distasteful in there.
if i leave the heat on for several days in a row during the day, my cat will start throwing up, hiding in closets.
reading earlier threads, i'm wondering if the sweet smell could be a glycol leak in the system? e.g. turning up the heat vaporizes it/makes it offgas more?
i know my landlord thinks i'm crazy, but i've had too many toxic episodes in older buildings to ignore symptoms like this (e.g. being diagnosed with hodgkins, when in fact it was a sick building - whole thing cleared up when i identified the problem - poof, no more "hodgkins", co poisoning a couple of times, chimney backdrafting particulants, etc.). i'd leave, but other than this, the apartment is wonderful, environmentally sound.
is there a way to show/prove that there is a leak, to convince the landlord to call in somebody? or is this just what these older units do and there's no fix, other than replacing the units?
also, if it is a leak/leaks, is it enough to keep the units off - or can pinhole/undetectable leaks in a cold system cause health issues?
any thoughts appreciated. :)
Leejosepho
DIY scratch-pad engineer
www.nonameyet.org
Sounds right to me. Leaking anti-freeze in a automobile heater can give off that same kind of odor.
Your local health department might be able to put you in touch with someone who has a sniffer to measure toxicity and maybe even find the leak. Or, look in your phone book and call the Poison Control Center and ask what you should do. And personally, I would either find a way to ventilate the place or sleep somewhere else until the problem is resolved.
A tablespoon or so of ethelyene glycol can easily kill a small animal...you may want to cage your cat before it dies. It can mess up their organs, so it may already be too late. It's sweet tasting, so they're attracted to it. Could be from various places, maybe the packing on the adjustment valve or maybe a leaking air vent.
yarrow
Washington
thanks for the input
thanks guys for your input - i'm keeping the baseboard heat off and providing ventilation thruout the day (can't leave windows open for extended periods due to pollution/pollen issues). no more chest pain since shutting it off. i've shut the baseboard flaps so the cat can't access anything.
interestingly, if i keep the apt. below ~68 degrees, no sweet odor. but if i allow the room temp to get upwards to 68 (using a separate space heater), i'll start noticing the odor again coming from the baseboard areas (faint at first, getting stronger if i allow the temp to climb) and i'll start experiencing chest soreness. which again, seems to point to glycol - it doesn't cause respiratory issues at lower temps, but will vaporize at the higher temps, causing inflammation of bronchial area.
i'll contact the health/poison control guys on monday.
Krow
Ontario, Canada
I'm just curious what glycol is even doing in the heating system......... unless its heating a parking garage or ramp........ in which case it would end up going through a heat exchanger anyway. The heating system should not have any glycol in it. It is possible to have a leak in the heat exchanger, but that may freeze in the garages or ramps when mixed with water.
I would definetly ask to have some tests done on the system, but it may not be coming from you radiators
yarrow
Washington
yeah, i know it sounds wierd. but it is somehow related to the heat registers. since i've kept them off, no more problems with the cat or me.
another tenant in the building is moving out because... her cat keeps puking and has stopped eating and the vet can't figure it out (after lots of visits/$$$ the vet is telling her it's immune system and is wondering if the cat is getting into something at home). i told her, hey, i don't know exactly what it is, but i can tell you what is causing your cat to be sick - told her to turn off her baseboard heat and loaned her a space heater, told her my cat had been doing the same thing for weeks until i figured out the cause. she checked back with me a couple days later - yep. fixed the problem. no puking, cat has come out of hiding, is eating food, moving around, back to old self.
re: fresh air. i open my windows every day, but anyone who has allergies will tell you (including weather.com, lung association, allergy sites, etc.) that you probably don't want to keep them open all the time due to pollens, particulants, pollution (hmmm... is there a reason all of these things start with "p"?)
another interesting correlation - the other tenant who is moving (an RN, not a nut case) started having a lot of the same symptoms i'd been having (e.g. rash/exzema, bleeding gums, waking up tired/fatigue when at home, sore throat, itchy eyes, etc. - which she only started getting when she moved in several months ago. again, the symptoms went away when she turned off her heat.
re: why would they put glycol in the system, the current landlord does not, but since they have never drained the system, it's the only thing i can think of. otherwise, why the chemical sweet odor that kicks in when you turn the heat up? (and i cleaned off all of the flanges/registers - squeaky clean - first thing i tried).
no, no lawsuits. i'm looking for another place. just trying to stay safe in the meantime. :)
Depending on where the boiler is, say an unheated space, it may need freeze protection if it were to fail. This sounds like a call to the local building inspector might be called for...check on-line in one of the health websites...I think that the symptoms will match up with glycol poisoning.
Frenchie
Jack of all trades
Other words starting with "P" - Paranoid, Paranoia, Pre-disposed to hysteria.
Glycol is an injested poison. Do you drink your radiator water, of which you have no evidence of its presence within?
Glycol is not a evaporative toxin and your radiators are not aerosolizing or boiling gylcol off of them.
Your building must have defective cats or you are downwind of some secret government nuclear test site. Get rid of the cats and get a canary. Set the cage on the radiator and turn it up full.... if it dies, you might have something to investigate. Until then, RN's are pretty weird broads in general, and I would move to Hudson bay if I had your level of life distress.
consider your apartment block as a fore front of natural selection - Those who cannot take enviromental poisons are now doomed to wither. Wither thou goest you will have problems.
Glycol vapor causes eye, nose & throat irritation - exactly the symptoms described. Consumption of glycol antifreeze causes nausea & vomiting - exactly the symptoms described.
Look it up.
Just because the OP can't find the leak, doesn't mean there isn't one.
Raucina
One of many types of glycol test results.
Comparative observations on the growth rates, blood counts, urine examinations, kidney function tests, fertility and general condition of the test and control groups, exhibited no essential differences between them with the exception that the rats in the glycol atmospheres exhibited consistently higher weight gains. Some drying of the skin of the monkeys' faces occurred after several months continuous exposure to a heavy fog of triethylene glycol. However, when the vapor concentration was maintained just below saturation by means of the glycostat this effect did not occur.
Examination at autopsy likewise failed to reveal any differences between the animals kept in glycolized air and those living in the ordinary room atmosphere. Extensive histological study of the lungs was made to ascertain whether the glycol had produced any generalized or local irritation. None was found. The kidneys, liver, spleen and bone marrow also were normal.
The results of these experiments in conjunction with the absence of any observed ill effects in patients exposed to both triethylene glycol and propylene glycol vapors for months at a time, provide assurance that air containing these vapors in amounts up to the saturation point is completely harmless.
. Glycol vapors are even used to safely disinfect rooms, having strong effects on staph bacteria.
No matter the test results, this guy is not injesting glycol, and the radiators are not aerosolizing anything except possibly cat urine.
Nate R
Milwaukee, WI
Is triethylene glycol different than ethylene glycol? I know propylene glycol is used as an animal-safe antifreeze. So what is it that makes it harmful? The ethylene? SOMETHING in antifreeze is toxic, there's no doubt about that, right?
irritation
1. Glycol is an antifreeze compound and there is no reason for it to be in your heating system, and since it is expensive and complicated to inject, I doubt that your owner was willing to invest the money when there were no returns for doing it. In fact there are mechanical, not health, downsides from using it.
2. If your system had a leak he would need to have the glycol injectors come by periodically and add to the system, and after a couple of sessions they would have tried to locate a leak. And when they knocked on your door, you would have told them where it was.
3. Even if you had a leak, it stretches the credibility to assume someone else also has a "phantom" leak that leaves no traces other than an odor when heated.
4. Male cats? If so, I would lean more to them spraying the radiation to mark their territory, than a glycol leak.
Cookie
Home
Yarrow, HD (hodgkins lymphoma) is really considered an environmental cancer. I know this because I have had for the past 10 years, NHL ( Non hodgkins lymphoma) Not to confuse you, NHL and HD are still both cancers, in the same league, only a different cell is found. They are both lymphomas. Now, Yarrow, I strongly suggest you seek another oncologist to make sure you don't have lymphoma. Reason being, I have never heard of anything like you said. I only wish with all my heart, it disappeared for you and for others effected, and hoping I don't sound selfish here, but for me, as well. I am not saying, you might not had been misdiagnosed for with lymphomas that is very easy to do but not with HD.
HD is the Reed Sternberg cell. Under the scope that cell takes on the appearance of a set of " OWL EYES." It is very difficult to mistake that. I am not saying it can't happen, just that the chances are slim to none. That is how the pathologist determines it is indeed, HD, Hodgkins Disease.
That in a nutshell is what makes me say to you, to seek another opinion here. HD actually has a cure rate, if found early enough. So, this is something you do not want to fart around on doing. If you have to have lymphoma, this is the absolute one, out of the several it could be, that you want to get.
I am sorry, but, if someone told you, lymphoma, please go. What you could have can be quite easily dealt with.
I don't know anything about what else you posted, but, I do sadly on this. I learned pretty much everything I could about lymphoma since I believe that knowledge is power; and when one goes to battle ( as in any war) you need to have every weapon available to you. I have even taught about lymphoma at the college level.
One thing you must not do is panic. Do it for those who love you. Just get another opinion, get more scans, another blood test and check your body for lumps, bumps, rashes, or make it fun and have someone else do it for you, lol, just do it.
One thing I absolutely hate to mention is the fact that their is a relationship between cat scratch fever and lymphoma. When I was first dx'd in 98, my husband was with me and they saw he had some cat scratches on his arms. They questioned him about it, (entering it into my medical records) and questioned me if the cat ever scratched me. Infact, he didn't; only my husband, because they played rough together, whereas, the cat and I would only snuggle together. Now, how fair is that, eh? He got scratched and I got the lymphoma, lol. Men. :)
If in doubt, there are articles on the net somewhere about the correlation between the 2. But, don't throw your cat away, I still have mine, and still never get scratched. I am just careful not to.
Good luck. I wish you well.
yarrow
Washington
"I strongly suggest you seek another oncologist to make sure you don't have lymphoma. Reason being, I have never heard of anything like you said. I only wish with all my heart, it disappeared for you and for others effected, and hoping I don't sound selfish here, but for me, as well. I am not saying, you might not had been misdiagnosed for with lymphomas that is very easy to do but not with HD. .."
no worries - that was several years back (2000-2001). after figuring out/remedying the environmental triggers and doing the detox work, got a clean slate re: pet scans (advanced form of xray) - all the lymph fluid and granulomas gone - poof. they call it remission, i call it figuring out what's going on in your environment and taking care of business (before it takes care of you). i get periodic xrays, just to check on things.
interesting statistic - oncologists will tell you that 85% of ALL cancers are environmentally induced.
another really wierd one (which is really troublesome when combined with the other) - epa, based on random checks are now reporting that 1 out of every 4 buildings being built today are sick buildings.
yarrow
Washington
FWIW, this does not apply if the cat is fixed.
cat piss/markings are very distinct odors. trust me, cat piss or marking odors are anything but chemical sweet. also, both cats in the building are neutered (mine is 15 yrs old, neutered since kitten, never sprays).
i've got another apt./duplex - move in on the 1st. i'm keeping the windows open just to be on the safe side, even tho the heat is turned off. the dry, itchy eyes, rash on face, bleeding gums is completely gone since turning off the heater. :)
yarrow
Washington
airborne glycol is considered toxic - check out osha and u.s. dept. of health services (just google airborne glycol respiratory) - even long-term exposure/inhalation of 1-25ppm will cause serious respiratory irritation, 80 ppm will cause "intolerable irritation" according to those sources (also you'll find similar reports on materials safety documents).
of course, i'm not saying that it is undeniably a glycol leak. i'm only guessing glycol because the smell and the symptoms appear to match up (cat piss odor doesn't cause burning eyes, rash, chest pain - or your cat to throw up) -- and who knows what they put in the system 40-50 years ago?
another interesting piece of info - the registers are pretty smashed up, from carpet cleaners banging up against them (the covers didn't protect the flanges and pipes, they've got pretty significant dents in them, especially the one in the living room, where the strongest smell comes from).
i'm still trying to get the mgmt. company to at least test the system - or flush it. even the city can't figure out why they are resisting doing these things, since they've had multiple complaints and both are simple, inexpensive checks.
Cookie
Home
Yarrow, what chemos did they have you on? Remission, yes, from treatments. What stage were you? That is good news you are in remission. I am too, for nearly 3 years now!
Dunbar Plumbing
www.KoldBreeze.com
(cat piss odor doesn't cause burning eyes, rash, chest pain)
I might be taking your words out of context, but I totally disagree with that statement.
As a "former" union service plumber working in rough areas of urban areas in cincinnati ohio, we would randomly enter homes that the concentration of cat urine was so high (ammonia levels) that you're eyes would burn red within 15 minutes of being in there.
Talk about people that have no clue about healthy living, it was deplorable what I've seen as an urban plumber. I don't subject myself to that anymore, too disturbing.
Anyway, when I'd write "Not fit for human life" on the bill, that indirectly changed lives for animals, adults and children in that specific habitation.
I only did it 3 times as my tour as a plumber over there, all 3 times deserved the health department coming in and removing all occupants.
1 of those 3 houses they tore down 6 months later. 321 Forbus Avenue off Queen City avenue on the west side....
sounds like something out of a horror movie which it was. DANGER
My mother seemed to think that injuries to the breast tissue is relevant to breast cancer. There was a correlation gathering on this matter but no statistical data to back it up.
Patrick Swayze is someone I would never think would have only weeks to live *5* but I hope they are wrong. The facts are a 4% survival rate when you're in your late 70's and 80's, he's gotten it in his 50's.
I'm thinking it's all that exposure to "dirty" dancing is what caused it. Shame. :confused:
Cookie
Home
Cat urine will sting the eyes and smell like ammonia is right. Plus, my mother had breast cancer and had an injury to the chest when she was a young girl. She was kicked in the chest by a horse. She also thought it was the cause. I don't know. Odd you should say that. Hmm. I have been beating the odds. I am so proud of that I could write in the skies. I put a holiday on the calendar in my fair city in 2001. It is, Remission Week. I worked with the mayor and we wrote up a proclamation. Remission Week is celebrated from June 24-June 30. My proclamation,
WHEREAS, every day people from all over the world and all walks of life face life-threatening disease and;
WHEREAS, after undergoing very difficult treatments in order to save their lives and;
WHEREAS, with great medical advancements many people experience a remission in their illness and;
WHEREAS, we, as a people, need to recognize the importance of a remission to a seriously ill person.
Then, the Mayor declared with his signature and seal:
NOW THEREFORE BE IT RESOLVED that I as Mayor do hereby declare the week of June24 through June 30 to be " Remission Week" recognizing the triumph of seriously ill patients over their life-threatening illnesses.
Our supermarkets give away balloons and we have some other events.
Now, I am working on legislating a new law.
yarrow
Washington
congratulations on the 3 years! wonderful news. :)
no chemos or surgery in my case - i refused treatment - they called it stage I hodgkins, but i suspect it was environmental issues masquerading as hodgkins. i was able to get rid of the symptoms on my own by figuring out the cause/removing myself from the problem, the symptoms totally cleared up (took several months to totally clear up the problem). they really didn't have much choice other than to say it went into remission.
the cause in that case was an older house w/a chimney that was out of commission that was backdrafting into our apartment - tested positive for mold the closer you got to the chimney, and who knows what else was blowing in - lots of bad juju inside chimneys (the landlord refused to put a chimney cap on it or even get it cleaned). i noticed that on windy days, we (my husband and myself) would wake up feeling like crap - leg cramps, extreme ankle and foot pain, edema, headaches, stomach problems, diarrhea - also, acid reflux and eye infections for him (that nobody could cure or explain).
i was able to semi-control the problem by blocking the unused fireplace opening with plastic. he signed on for unnecessary circulation/leg surgery when he got to where he couldn't walk more than a few blocks (the surgery did absolutely nothing to fix the problem). i got the hodgkins stage I diagnosis. of course, both cats had started throwing up not long after we'd moved into the place and continued throwing up "hair balls" the entire year we were there - now we know what that means - it means you've got a sick apt/house and you better figure it out/fix it - or leave.
bottom line - it took us awhile to figure out what was going on (it was just electric baseboard heat, no gas in building, so i knew it wasn't CO). we finally identified the problem as an uncapped chimney, but the landlord refused to fix it (again, a very simple, inexpensive fix), so we moved. cats stopped throwing up and our symptoms went away (cecil's walking problems cleared up within a few weeks). i also did xi gong to help remove lymph/edema buildup, and drank a gallon of green tea/day to help w/detox. took about 5-6 months to totally clear up the lungs/lymph glands, get my energy back to normal state and get the clear pet scans/clean bill of health from my doc.
no chemo. no radiation. no surgery. no meds. the whole experience has made an avid believer out of my husband (who's now back to hiking/biking with the best of them). you can believe he's not going to be signing up for any surgeries in the future without first checking out his environment.
i'm not saying all diagnoses are wrong, or that i wouldn't have signed up for treatment if i couldn't identify an environmental trigger. it's just that there are a lot of mis-diagnoses, and environment "bumps in the night" that present as other things when you go to the doc. it's just good to do your own detective work in this regard.
a friend of mine was on 4 different meds - anti-depressants, ADD, sleep meds and i can't remember the 4th, before i helped her identify that her family's actual problems were related to CO leaks from ducting that had moved apart from years of the house settling. the simple test of turning off her gas appliances for a couple of days was all it took to convince her (then of course, she had to pay someone to find the CO leaks, which led to replacement of the ducting - about 3K, but she says it's a lot cheaper than all the doctor visits and medications she'd been through since buying the house a few years back).
environmental doctors are trained to look for this stuff, some are better than others i understand - but most docs are not trained in this regard - only to diagnose/treat the symptoms they see.
