Sweating near pipe dope
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Viking, Mar 14, 2011.
  1. Viking
    Viking New Member
    Feb 3, 2011
    Wisconsin
    I am using Oatey Great White Pipe Joint Compound to seal the threaded connections on a shower valve, and will need to sweat an elbow very tight to this connection. Will the pipe dope handle the heat? Or will this cause problems? Thanks for any info.
  2. hj
    It all depends on YOUR technique in soldering. I, and most plumbers, could do it without damage, but then we might also figure out a way to avoid the problem entirely. We do not know how proficient you are, so YOU might overheat the joint and cause the threaded connection to fail, or underheat it and create a "cold joint".
Similar Threads: Sweating near
Plumbing Forum, Professional & DIY Advice sweating near main shut off Mar 19, 2008
Plumbing Forum, Professional & DIY Advice PVC Drain Pipe Sweating Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Verticle Sweating, Ridgid Copper Dec 20, 2016
Plumbing Forum, Professional & DIY Advice Sweating shower valve help Nov 29, 2016
Plumbing Forum, Professional & DIY Advice sweating horizontal joints Dec 6, 2014
