Hi all...
I'm remodeling my kitchen/family room and have found myself learning some new things. I've capped off some copper pipes, which I found pretty easy to do , but I've run into a bit more difficult plumbing issue:
I need to move the water supply for the refrigerator about 6 inches to make room for a larger pantry. Currently, the valve sticks out from the wall. I bought one of those recessed boxes with valve, so the valve won't stick out anymore. The instructions say to solder the copper to the brass valve. Since this will be in the wall (rather than the current valve which is compression and accessible outside the wall), I feel that soldering would be best (plus the fact I don't appear to have any other options).
So, here's the question(s): I bought the plumbing kit with flux, solder, etc. in it (already had a propane torch). Can I use the same flux, solder, torch for joining brass and copper? How long does it take to heat the brass? The brass appears to be about 1 1/2" deep - do I put 1 1/2" copper inside it? If so, how much solder will that require? Please add any additional information that I may have neglected to ask about.
I have read other posts, so I know I'm suppose to open the valve.
THANKS!
THANKS!
