Swap toilet and sink...and then some
Discussion in 'Remodel Forum & Blog' started by Not a plumber, Dec 8, 2004.
  1. Not a plumber
    Not a plumber New Member
    Dec 8, 2004
    NJ
    Hi all...first time posting, but have visited many times...
    I bought a cape about 2 years ago, built in 1950. The second floor was finished in the 60's or 70's. The time has come for a little remodeling....
    In the second floor bath (full) I want to rearrange the sink and toilet locations, the current layout is not very appealing. All the walls/ceilings have been stripped to studs (to reveal a lovely insulation that amounts to little more than corregated paper sandwiched with tinfoil :eek: ). These two fixtures are on the same wall, but seperated by the main vent/stack(cast) and a chase for same - sticks out about 20" from wall, about 8" wide. At the top of the stack is a connection for venting the tub/shower (copper). In the very near future, the roof will be replaced - very small leak in roof where stack exits thru roofline. Eventually, the bath on the first floor will also be gutted and remodeled ~ cosmetically - tiles and new fixtures, no real moving of locations.
    Would it be best to remove the cast that is there and replace with ABS/PVC? or just use the sheilded fittings/adaptors to reconnect?
    What are the clearances/layout for a new toilet (rough-in)?
    What are the clearances/layouts for a sink (drian/supply) - the sink will have a base cabinet.
    :confused:
    Any help, comments, tips will be appreciated.
    (Photo/scan shows existing layout)
Similar Threads: Swap toilet
Remodel Forum & Blog Swap Toilet and Shower Locations Mar 18, 2013
Remodel Forum & Blog Swapping tub and toilet--how much work? Nov 26, 2004
Remodel Forum & Blog slide in range swap out with free standing Mar 11, 2009
Remodel Forum & Blog swap laundry room to half bath Sep 10, 2008
Remodel Forum & Blog Toilet pipe not 100% vertical -- how "out" can it be? Feb 12, 2017
