Swap Disposer on dual basin sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by alexh, Jan 18, 2014.
  1. alexh
    alexh New Member
    Jun 18, 2009
    California
    Hi all,
    I have a dual basin Kohler sink and the counter workspace is on the side w/o disposer. That plus the fact that the main drain is perfectly horizontal for a bout 3' means that it stops up regularly. I have cleared it so many times I can do it in about 10 mins but it's still a royal pain.
    Obviously Kohler intended the disposer be on the right side (small basin) since the hole for the dishwasher air gap is on that side but nothing is preventing me from putting the disposer on the left side?
    Just wanted to be sure before I take it apart. The dishwasher air gap to disposer drain will be a long run but I don't see that this will be a problem.
    I may be able to improve the slope on the main drain slightly but I'm thinking of adding a cleanout adapter. I'll still have to catch the water in a pan but at least I won't have to take apart the trap.
    Thanks
  2. jim mills
    jim mills New Member
    Jan 9, 2014
    nebraska
    I don't see any problem with changing it out at all. Looks like you could shorten that discharge elbow on the disposer and the tail piece on the other sink an inch or so and gain a little height.
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    How old is the garburator? The blades become dull over time and can cause blockages. If its anywhere near 6 or 7 years old I would recommend a new one.
  5. hj
    There is NOTHING in your photo that gives any indication that changing the disposer's location will have anything to do with preventing stoppages. You have something else causing them. "Perfectly horizontal for 3 feet" does NOT cause stoppages.
  6. Terry
    Aug 17, 2004
    Replace that dinosaur of a disposer.
    When they get old, they no longer chip up the food and stoppages become a daily problem.
    I like the Insinkerator Pro series.
    Spend a little more on a nice disposer and less on plumbers.
    And yes, you have plenty of room there to change sides.
    The PRO Insinkerators we sell and install have longer warranties than the Evolution Series
  7. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    The only "disadvantage" is that the right side sink is not as deep as the left side.
  8. alexh
    alexh New Member
    Jun 18, 2009
    California
    Here is the main drain from sink to exterior cleanout. The stoppage is always in this section. The stoppages are really easy to clear - I used to use a coat hanger.
    I think a new disposal on the work side will prevent lager debris from going down the drain.
  9. hj
    There is also nothing about that section which should cause a stoppage, unless your disposer is worn out and you are NOT using adequate water flow.
  10. jim mills
    Jan 9, 2014
    nebraska
    Looks to be going up hill to me
  11. glazer1972
    glazer1972 New Member
    Feb 19, 2014
    East Texas
    Insinkerator Pro 1100xl would like solve your problem. It does a much better job of grinding the food up.
  12. hj
    The "Pro" series is advertised as "Only available to professional plumbers". So it will probably be a few months before HD has it, just like the "plumber only" Evolution series they now sell. If the pipe is going "downhill", raise it, the opening looks large enough. Plastic pipe flexes very easily.
Similar Threads: Swap Disposer
Plumbing Forum, Professional & DIY Advice Kitchen Sink drain needs to lower; could I swap drain with stand tube? May 13, 2016
Plumbing Forum, Professional & DIY Advice Remodel Q: swapping a tub location for a vanity Mar 14, 2013
Plumbing Forum, Professional & DIY Advice Swapping Toilet and Shower locations Oct 30, 2011
Plumbing Forum, Professional & DIY Advice Tub/Lav Swap- Need advice on venting! Oct 15, 2007
Plumbing Forum, Professional & DIY Advice swap double sink with bathtub Apr 12, 2007
