Surface Pumps
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chefwong, Nov 1, 2012.
  1. chefwong
    chefwong Member
    Jun 14, 2006
    District of Columbia
    Can anyone recommend a very shallow water height water surface pump ?
    I have others....
    This pump does not need to be super robust as I'm just pumping it into a *container* in which a Zoeller will be doing the duty.
    Does such a beast exist.
    I had planned to use a wet vac for this application but you would be amazed how fast 5 gallons fill up......
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
  5. hj
    The Little Giant pumps with the intake on the bottom will pump down to about a 1/2" from the surface.
  6. chefwong
    chefwong Member
    Jun 14, 2006
    I have a wayne that does the same down to 1/8. The issue is to get it primed and pumping, it wan'ts like 2 1/2" if I recall
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Time to get the jackhammer out and make a pit or buy that shop vac with pump out.
Similar Threads: Surface Pumps
Plumbing Forum, Professional & DIY Advice Utility Surface Pumps - Zoeller Vs. Wayne Aug 26, 2011
Plumbing Forum, Professional & DIY Advice DIY no grout solid surface shower suggestions? Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Trying to surface cleanout above finished floor May 16, 2016
Plumbing Forum, Professional & DIY Advice Water bubble out from concrete slab surface when the downhill 12-foot far away kitchen sink is dra Sep 25, 2014
